  New Posts New Posts RSS Feed - USB using 15mm ply
USB using 15mm ply
xlogic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote xlogic Quote  Post ReplyReply Direct Link To This Post Topic: USB using 15mm ply
    Posted: 28 January 2008 at 1:09pm
I can only find plans for usb using 18mm ply.
If I use 15mm ply then some of the internal dimentions will be slightly larger. If this sacrifice has to be made is it better to make the rear(back of the driver) chamber bigger or the front chamber bigger - or to make them equally bigger
Alternativley - are there any 15mm plans about?
Disco Stu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Disco Stu Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2008 at 1:17pm
The difference will be negligible
However using thinner ply you should try and put in a bit of extra bracing
I mostly use 12mm and so long as you brace as close to every 6" as possible (but you can drill holes in the braces to allow sound to pass through) you should be fine
Stu
All you need to know is:
My acts:
Post Options Post Options   Thanks (0) Thanks(0)   Quote mobiele eenheid Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2008 at 1:26pm
Volume differences between single cabinets made from 15 mm and 18 mm, are in the 7,5 liter range. Evenly divided over both chambers (and horn) the differences can be neglected.
Adding only to the rear chamber will improve the low end response a bit, in exchange for a bit lower mechanical powerhandling.
Johan
Post Options Post Options   Thanks (0) Thanks(0)   Quote xlogic Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2008 at 2:50pm
Thanks guys, I think ill try and do it so the all the chamber sizes increase as evenly as possible and look out for where I can put more bracing.
Although the extra bracing will actually reduce the chamber size
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2008 at 9:01pm
id make the cab 9mm thinnier [stacked horizontaly]  and 3mm less deep, that would compensate it adequatly???
insert silly sentence here
Post Options Post Options   Thanks (0) Thanks(0)   Quote xlogic Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2008 at 9:25pm
will the thickness of the wood be noticably detrimental to strength and sound quality
Strange Daze View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Strange Daze Quote  Post ReplyReply Direct Link To This Post Posted: 29 January 2008 at 12:27pm
mmm..USBs dom??
..what ya got in mind??
...you not getting rid of ya loonies are ya??!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote xlogic Quote  Post ReplyReply Direct Link To This Post Posted: 29 January 2008 at 7:43pm
well they are to go above the punishers. the looneys aint mine they are nicks but i think he is getting rid possibly to buy punishers
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 29 January 2008 at 10:38pm
xlogic: We're going to have quite a bit of kick then, Xtros, Puns and USB!
Post Options Post Options   Thanks (0) Thanks(0)   Quote xlogic Quote  Post ReplyReply Direct Link To This Post Posted: 30 January 2008 at 11:12am
yeah i cant afford xtros atm and I have all this wood sat here threatening to go mouldy on me! and with the workshop just sat there doing nothing it seems a shame not to build something!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Strange Daze Quote  Post ReplyReply Direct Link To This Post Posted: 30 January 2008 at 12:19pm
you have a workshop X??
.....I may have to blag a day in there if ya dont mind...
Got some double 15" reflex to build...Shouldnt take more than a day or two if i have the wood pre -cut??
anychance??
Post Options Post Options   Thanks (0) Thanks(0)   Quote xlogic Quote  Post ReplyReply Direct Link To This Post Posted: 30 January 2008 at 12:47pm
not mine its bonuses its available for anyone to use for donations towards the rent, theres a massive table saw in there,
