Use Behringer X Air XR18 as zone mixer? |
Post Reply | Page 12> |
serioussound
Registered User Joined: 01 December 2013 Status: Offline Points: 443 |
Posted: 15 March 2021 at 6:33pm |
Im new to mixers in general and I want a cost effective solution for controlling different rooms with an ipad or pc. Mostly just volume level for each room.
Can this be done with the aux outs of the Behringer X Air XR18 it does only has one main out. Or do you guys know any other cheap solution for this? |
APW
Young Croc Joined: 13 November 2012 Location: Kent, UK Status: Online Points: 1174 |
you need a zone controller.... something like the Adastra Rz45 won't break the bank....it has bluetooth and USB conectivity as well as inputs for wall mounted control panels.
serioussound
But it has no ios app or pc control?
And not balanced out?
serioussound
Maybe a Behringer X32 Rack is a good way to go?
Tinnitus Rex
Registered User Joined: 31 October 2020 Status: Offline Points: 287 |
Yes . Aux outs are very often used to feed stage monitors/"zones". If all the individual channels aux levels are set to "10"and are set to post fade they will respond the same as the main outs , you lower the channel fader and all levels will drop . you would use the aux master faders to adjust relative zone levels. adding channel compression/limiting on the inputs it should look after the system
imageoven
Old Croc Joined: 28 March 2007 Location: Scotland Status: Offline Points: 2186 |
not sure it will suit your budget though?
APW
Sorry about that, I realised once I'd posted.... another contender is possibly the Soundcraft Ui24R or Ui16 Edited by APW - 15 March 2021 at 8:23pm |
serioussound
Yes put the Behringer X32 is the most powerful for the price?
APW
If he doesn’t mind used there’s one on eBay currently at Behringer money. |
serioussound
But the Behringer will let me do more stuff that the Cloud right?
APW
In your opening post you said you mainly just needed to control the volume of each zone.
serioussound
Yes but for same price a Behringer will do alot more right?
I need to have the E model of the Cloud am I right?
