Users crest 10004 on sub (advice/findings) ? |
Post Reply | Page 12> |
Agayu
Registered User Joined: 18 February 2019 Status: Offline Points: 46 |
Posted: 12 February 2020 at 12:49pm |
Greetings, Bless
mk2_ginger_biscuit69
not really powerful enough by modern standards should you be looking to power anything big......
Dub Specialist Sound
Great amps , great bass....as long you dont want to drive zillion what drivers , go for it...
Pinyorouk
Young Croc Joined: 31 January 2011 Status: Offline Points: 551 |
Lookup Crest 8001 as the 10004 is 2*8001 in one enclosure.
Agayu
We would like tot power 4 hog scoops with them loaded with pd1850's...
Is that to much because if i just look at the specs it should do the job :) Thanks for the advice !
Edited by Agayu - 13 February 2020 at 9:36am |
Agayu
Would be to power 4 x hogscoop (loaded with pd1850) :)
But since we dont have the budget to buy a powerfull new lightweight amp we wanted to start off with the 10004.. also heard a lot of good things about the 8001 for bass but was hoping to speak to some users to make shure we don't make a mistake buying one :) Thanks !
smitske96
Young Croc Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 1092 |
That's 750 Watts per driver, bit on the low side.
concept-10
Young Croc Joined: 17 May 2016 Status: Offline Points: 1293 |
The rated output would be a bit low but the 8001 is one of the best bass amps ever, are you going to be driving them to death? if not you will be presently surprised by how it sounds, 10004 is a gorgeous amp |
Agayu
Edited by Agayu - 13 February 2020 at 10:27am |
Agayu
Agayu
If played @ 8ohm it would be on the low side yess but i think still enough for most venues we going to play.
But when played @4ohm bridged we got 1400 per driver or am i wrong ? Still a beginner in al this so might be wrong :) Thanks for clearing that up ! |
Agayu
Edited by Agayu - 13 February 2020 at 10:28am |
