  New Posts New Posts RSS Feed - Users crest 10004 on sub (advice/findings) ?
Agayu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Agayu Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2020 at 10:28am
Originally posted by concept-10 concept-10 wrote:
Originally posted by Agayu Agayu wrote:
We would like tot power 4 hog scoops with them loaded with pd1850's...
Is that to much because if i just look at the specs it should do the job :)
Thanks for the advice !
The rated output would be a bit low but the 8001 is one of the best bass amps ever, are you going to be driving them to death? if not you will be presently surprised by how it sounds, 10004 is a gorgeous amp Smile
It's like you say, i dont think we are going to drive them to death no..
For most of the smaller venues we will be playing i think its more than enough but like i said i'm still a beginner so it's hard to know for sure :)
Think i'll be taking the risk than since you and a lot of other soundpeople keep saying that they sound awesome..
Thanks dor the help man
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2020 at 10:43am
FACT crest are one the best sounding/quality amps ever built, simple...ued to see these amps run for days on end rolling out sub, no problem at all
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2020 at 10:45am
8001
food for thought...specs state 1250 @ 4 ohms, I bench tested it, it was showing 1850w @ 4 ohms and 22 Hz which is extremely impressive. ..old skool brutes
Post Options Post Options   Thanks (0) Thanks(0)   Quote Agayu Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2020 at 11:52am
Dammn impressive that is the least you could say :D
Hopefully its enough to power the newer modern drivers (4 × pd 1850) but if i get youre post right it should be more than enough :)
We will be playing reggae/dub music so lets hope we have a fine bass section with that combination !
Bless !
Edited by Agayu - 13 February 2020 at 11:55am
smitske96 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2020 at 1:29pm
Yes, but expect a big amount of current draw.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Agayu Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2020 at 1:46pm
Yep so we have been told :) thats also our biggest concern...
Normaly we will only play if got a decent 32 A supply and will be plugged into our rack powerdistributor with a slow curve. Hopefully thats enough...
You think it would be oke when we do it that way ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2020 at 2:01pm
Yes correct only down side to old skool crests , not efficient amps at all comparing to today's amps , tha love big draw currents, way better on a 32a supply...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Agayu Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2020 at 2:35pm
We'll make sure we have a 32A plug than !
Is it possible to play without a 32 A plug ? Asume they will clip faster and play less loud ?
Maybe some small local venues dont have such powersuply so theres a chance we need to play without in some cases..
paulus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulus Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2020 at 2:48pm
bridge each side so its a 2 chan amp and run 2 pds at 4 ohm per bridged section, works fine mate has one plenty of power and will sound great may struggle on a 13 amp feed tho when reaching pd 1850 growl levels
TRENDSETTER SOUND SYSTEM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Agayu Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2020 at 3:30pm
Superb !
Thats what we wanted to do so thanks for clearing this up :)
This page was generated in 0.102 seconds.
