  New Posts New Posts RSS Feed - Uses for 6.5ohm LAB12 Drivers
Requiem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Requiem Quote  Post ReplyReply Direct Link To This Post Topic: Uses for 6.5ohm LAB12 Drivers
    Posted: 18 December 2023 at 1:58am
Hiya guys
Come into possession of a load of these from a job lot which i'm trying to sell and I just wanted to know more about how they can be used,
I know they are the drivers designated for the LAB sub, but can they be used in anything else?
How does it work with the 6.5ohm load and the dual loading in the lab horn, i vaguely remember reading something about it on here about the cab design changing the ohm load or something but Ive been searching the forum for ages and couldnt find the right thread
Any links to correct thread or other uses would be great, thanks.
www.requiem-soundsystem.com
Custom Martin Audio WSX, USB & CSG Soundsystem based in Bristol
Lucasdude View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lucasdude Quote  Post ReplyReply Direct Link To This Post Posted: 18 December 2023 at 11:05am
The specs are unusual. Fairly high qts, very low sensitivity, only a 2.5" vc for a claimed 400w handling and also a fairly low BL. I would think with such a low resonance  that they would probably work in a sealed box for HC, or in pair in a reflex box for a car. Although the 6ohm impedence isn't ideal for a car amp, a muscular one should push a parallel pair OK.
Xoc1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Xoc1 Quote  Post ReplyReply Direct Link To This Post Posted: 18 December 2023 at 1:08pm
Lab 12's have been used Reflex & tapped horns as well as FLH
JonB67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 19 December 2023 at 11:22pm
Keystone also does double 12" labs iirc.
Definitely worth a look.  Think member doller on here also built some subs with labs of his own design. Google the archives!
sarsen1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sarsen1 Quote  Post ReplyReply Direct Link To This Post Posted: 20 December 2023 at 10:12am
Loads of info on tapped horn designed for this driver here: $325 Lab 12 based PA tapped horn ~ 35Hz extension | diyAudio
