Using a combination of Powersoft K and T series |
swoo
Registered User Joined: 01 September 2014 Location: London Status: Offline Points: 137 |
Posted: 11 March 2020 at 10:28am |
I am looking to upgrade amplifiers for my system.
Ideally I would like to use a K10 and T604 Can I connect these via RJ45 and control them together via Armonia? Despite the T series using Dante while the K series does not. Thanks
merc 313
Registered User Joined: 02 August 2009 Status: Offline Points: 84 |
We use a managed switch for 4 K10 and 3 T604. but Yes they will work just daisy chained together ,The K 10 will ignor the Dante signal. |
wires
Young Croc Joined: 21 May 2009 Status: Offline Points: 1365 |
If you mean will the software identify the amps if the rj45 ports are all linked together; then yes.
T series won’t work on armonia, only work on armonia plus. K series dsp; you have to load a preset then change via the armonia plus software. Also remember to setup any t and x series into k series latency mode. |
swoo
Thanks that has been very helpful.
