using an X1 for home cinema |
Post Reply | Page <12 |
tb_mike
Old Croc Joined: 01 October 2004 Location: New Zealand Status: Offline Points: 2744 |
Im not sure of the exact X1 tunings so,
As a comparison,400w input, BP6 jbl2242 200L 32hz 56L 82hz 26hz = 9mm excursion. 4th order highpass at 26hz works out just fine.Even a 2nd order works fine at this power level. Bear in mind spl is in the mid 120s at this stage. |
ceharden
For home cinema use you could probably adjust the X1 to go a even lower at the expense of a little efficiency.
tb_mike
Yeh you could extend the ports externally. Quite the opposite to those generic 10"1cubic ft 'ht subwoofers' ehehe
