Using PD186 in 1850 horns, is it adviseable?!?!? |
Post Reply | Page 12> |
stem
Registered User Joined: 14 February 2007 Location: Liverpool Status: Offline Points: 45 |
Posted: 07 March 2007 at 5:44pm |
Hi,
would it be possable to use PD186 in the 1850 horns? Would it make much difference? What would I be loosing compared to the PD1850 appart from the 100watts difference? Thanks Ste |
Mark James
if it didnt make much difference do you think rog would have made the new design...... put the pd186 in the 186 horn.... almost identicle to build..........
Insomnia
Old Croc Joined: 06 September 2005 Status: Offline Points: 1721 |
true-
i heard 2 1850 horns loaded with pd186- they weren't that bad- but very ineffecient-
build/get built some 186 horns and chuck some PD186's in, i only heard 2- but if u get 4 they will be lots of fun...
stem
Im very short on cash you see, so was wondering if there where any cheaper drivers that could in the 1850
Thanks Ste |
Mark James
just use the 186 horn loaded with pd186 or even better if you can stretch a little v-18 [void] in 1850.....
seriusly though... the pd186 in a 186 horn will be a hundred times better than a pd186 in a 1850 horn.....
the only difference between the boxes is the rear chamber size being suitable for the said drivers......
putting the pd186 in an 1850 horn will be effectively sabbatage of your own gear...
why make something and deliberately make it not work properly????
norty303
I think this might be a case of so that he can say 'I've got some 1850's' rather than 'I've got some 186's'
Unless of course Ste already owns/has bought some unloaded 1850's and wants to know cheaper alternatives.
stem
yeh, i build the 1850 and need to buy the driver so was wondering if there was a cheaper alternative but would give the same sort of punch and quality.
norty303
Well nothing will punch like the 1850, and if you wanted quality you should have built the 186 instead.
So most if not all other drivers will give less punch, but you may get slightly better quality.
stem
what other drivers do you recomend then?
thanks Ste |
norty303
Void V-1000 is a popular choice, although not too sure on availability at the moment. Not a huge amount cheaper than the 1850 though.
tears
Registered User Joined: 05 August 2006 Location: Trinidad and Tobago Status: Offline Points: 41 |
the RCF L18 P300 is what i use. |
I will not quit
stem
what does it sound like?
