  New Posts New Posts RSS Feed - v 18 1000
v 18 1000
nuclearbass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuclearbass Quote  Post ReplyReply Direct Link To This Post Topic: v 18 1000
    Posted: 18 December 2010 at 10:35am
hi, any 1 know the measurements for the v 18 so that i can get the speaker brac in place on my x1, as my drivers arnt gunna be due till the new year and i really wanna crack on with this
AndyWave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndyWave Quote  Post ReplyReply Direct Link To This Post Posted: 18 December 2010 at 5:09pm
From bluearan website
General Specifications
1000 watts RMS
5"/127mm voice coil
Cast chassis
Double Spider
288mm magnet
technical Specifications
Nominal Imp - 8Ohm
Power - 1000 Watts Rms
Coil Size - 127mm
Suspension - Double spider
Cone type - paper/fabric surround
Dimensions - 463mm Dia x 187mm Deep
Net Weight - 17.8Kg
Gross Wieght - 20.8Kg
Baffle Cutout - Rear Mount 425mm
Front Mount 430mm
Mounting Holes - 8 x 8mm (442mm Dia)
Thiele Small Parameters
Fo - 34.5312Hz
Qts - 0.2155
Qms - 7.6346
Qes - 0.2218
Vas - 201.7245 Litres
BL - 34.8880 TM
no - 3.6212%
Sd - 0.1230 sqM
Xmax - 10.5mm
Pwr - 1000 Watts RMS
Cms - 93.8967 uM/N
Mms - 226.2389 Grams (Total mass)
Mmd - 201.4347 Grams (Diaphragm Mass)
Re - 5.5000 Ohms
Le - 1.1848 mH @ 20KHz
Le - 2.2024 mH @ 1KHz
zo - 194.8128 Ohms
Rem - 9.4005 Ohms Res @ 1KHz
Rem - 49.2902 Ohms Res @ 20KHz
Krm - 74.5321 mOhms
Kxm - 13.4542 mH
Erm - 0.5531 (resis expont)
Exm - 0.7931 (resis expont)
A
torturing electrons since ......
