  New Posts New Posts RSS Feed - V18 cut out
V18 cut out
Amplighting&sound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amplighting&sound Quote  Post ReplyReply Direct Link To This Post Topic: V18 cut out
    Posted: 27 June 2012 at 8:26pm
Can any one help i need to make the cut out in my 1850s bigger for the v18 as its bout 5mm to small any help would be lovely
hmaudio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hmaudio Quote  Post ReplyReply Direct Link To This Post Posted: 27 June 2012 at 8:50pm
on the pdf i have for the v18-1000 it says rear mounted is 425mm and front mounted is 430mm
hope this helps
cheers
Adam
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amplighting&sound Quote  Post ReplyReply Direct Link To This Post Posted: 27 June 2012 at 9:52pm
Thank u m8 but i hav that info its just the cut out needs to be bigger but how do u get a routa in to do it please help lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote hmaudio Quote  Post ReplyReply Direct Link To This Post Posted: 27 June 2012 at 10:13pm
if the cab is already built its going to be hard to make the cut out bigger.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amplighting&sound Quote  Post ReplyReply Direct Link To This Post Posted: 28 June 2012 at 6:39am
True dem cab is allready made would it hurt if cut out was 5mm to small would this make cone rub
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amplighting&sound Quote  Post ReplyReply Direct Link To This Post Posted: 28 June 2012 at 9:52pm
Any 1 got any input
Vert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Vert Quote  Post ReplyReply Direct Link To This Post Posted: 28 June 2012 at 10:24pm
and a Rotary rasp + alot of patience
Box builder, pm for quote
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amplighting&sound Quote  Post ReplyReply Direct Link To This Post Posted: 28 June 2012 at 10:59pm
Do well thank u
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amplighting&sound Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2012 at 9:08pm
Hello again just tryed the rasp and its a very slow process does any one hav any other ideas please
infrasound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote infrasound Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2012 at 9:23pm
If it's only 5mm you should be able to use a chamfer bit on a router.
Set it so that the bearing just about catches the inside wood.
Post Options Post Options   Thanks (0) Thanks(0)   Quote infrasound Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2012 at 9:27pm
Like so
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amplighting&sound Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2012 at 9:30pm
Thank u infa but my prob is i can only gt my trimer round the bottom half of cut out as the chamber gts narrow at the back ?
