'Value for money' light show |
Page <123> |
mini-mad
Joined: 13 July 2012 Location: london Status: Offline Points: 6861 |
Posted: 27 January 2014 at 1:03pm |
..i looked at a couple of them. for 150 peeps 2 is minimal, 4 is good... 6 fully controlled and programmed will be fantastic!
monkeypuzzle
Joined: 25 January 2005 Status: Offline Points: 1046 |
Posted: 27 January 2014 at 2:19pm |
Couldn't agree more. Lighting is more than some fast moving colour changing beams in smoke (OP, you'll need a hazer or smokie BTW). It sets the atmosphere, Can't go wrong with 4 martin destroyers and a few megastar strobes for the dirty rave (fast moving beams nonsense!), for a deep house and percussive techno style, bin off the movers, get it as dark as you can and just put in a few leds on red/congo blue around lighting the space, psytrance, fill it with uv and spike everyone with . In the same way you would think about where you put you stacks, think about and experiment with where you put your LX. It takes a bit of thinking about to not look like a wedding dj with a wobbly goalpost above the decks, where you put the lights in the venue is as important as what lights you have. |
Goodvibetribe
Joined: 06 December 2011 Location: Cardiff Status: Offline Points: 951 |
Posted: 27 January 2014 at 4:28pm |
[/QUOTE]
It sets the atmosphere, Can't go wrong with 4 martin destroyers and a few megastar strobes for the dirty rave (fast moving beams nonsense!), for a deep house and percussive techno style, bin off the movers, get it as dark as you can and just put in a few leds on red/congo blue around lighting the space, psytrance, fill it with uv and spike everyone with . . [/QUOTE] +1
George c - www.gorilla-audio.co.uk facebook.com/gorillaaudiohire
andycw
Joined: 17 November 2010 Location: Norfolk Status: Offline Points: 994 |
Posted: 27 January 2014 at 4:32pm |
Yep, smoke is on the list as well.
I hired one a few years ago, ran off a canister rather than fluid. Thing was bleddy brilliant |
No Bass No Fun
mk2_ginger_biscuit69
Joined: 03 November 2008 Location: Brighton Status: Offline Points: 7797 |
Posted: 27 January 2014 at 4:39pm |
those refills aren't cheap though! We have a few handheld canister machines on the paintball site! Love it when you have a load of people in a bunker and you smoke em out... trying to pursuade the owner to let us put some strobes around the place too but is a H&S hazard it would seem ![]() |
imageoven
Joined: 28 March 2007 Location: Scotland Status: Offline Points: 2199 |
Posted: 27 January 2014 at 5:28pm |
If they are the ones I'm thinking of they came in a variety of versions. Early ones used a conventional transformer for a filament lamp and were quite reliable, later they changed to a SMPS which was les reliable and then they went to LED instead of filament lamps. Moving mirror lights really need to be positioned on stands or such like so that you can get them high up and symetrical (or not, but set up in a way that the movement of the beams compliments each other when moving together, rather than appearing unsychronised). |
Posted: 27 January 2014 at 5:44pm |
for cheap scanners, i can't recommend abstract VR8's [or better,
VR8R's - R=rotating gobo] enough, very good output for the unit, and also has some
brilliant chases built in, 150w HMI...
you can make on a master, chain the DMX, then assign the slaves a number of 1-4, allowing a straight line of 1-4, or if you have multiples you could do 1-2-3-4-1-2-3-4 etc etc. heres an old vid of my old Vr8r units, picked up £200 for the four with cases clamps and lamps!! Set sound/light left-right 4-3-2-1. Oldschool martin flower thing in middle, and pair of random lasers. Edited by mk2_ginger_biscuit69 - 27 January 2014 at 5:44pm |
njw
Joined: 26 March 2010 Location: S. Wales Status: Offline Points: 2700 |
Posted: 27 January 2014 at 5:54pm |
I have four of the led dynamos and for the price you can't go wrong, if the ones on facebook look older they could be the 250w version which are very bright but will eat replacement lamps if you use them a lot or the cheaper 100w versions which are still a great effect but I never found them particularly bright. A bit of smoke or haze to highlight the beams is a must though as said.
imageoven
Posted: 27 January 2014 at 8:12pm |
Horrible to service though! |
Posted: 27 January 2014 at 8:25pm |
just don't break them
![]() nah i found the few faults easy enough to fix, had a stepper go, easy swap out, and another one needed fairly major surgery but nothing a few hours and a replacement main board couldn't fix [that's one i dropped anyway! ]. |
mini-mad
Posted: 27 January 2014 at 8:45pm |
There is the odd company that will knockmout batchs of 25 boards or so for a fair price. Is there any ic on board that need programming or is it all off the shelf componants? Im asking as if you like them that much it might be worth banging a few boards together yourself.
Posted: 27 January 2014 at 8:53pm |
i found spare [often used] parts readily available, often on ebay or on first page of google searches.
the main board does contain much of the fixtures electronics, including their custom programs! Either way i got up to earning 8x units, and the only problem i had was a dead stepper motor, and a ballast [and the main board when i dropped one off a truss!]. Like most things, get ones that are in reasonable condition and look after them will be fine. Remember using the set heathrow bought many years back - absolutely shagged condition!! |
Page <123> |
