Valve amplifier |
Post Reply | Page <123> |
jbl_man
madboffin
Old Croc Joined: 03 July 2009 Location: Milton Keynes Status: Offline Points: 1538 |
You probably know what these amplifiers sell for. But if not, do an online search and sit down before looking at the numbers...
The main thing to watch out for, apart from all the electrolytics, is the paper capacitors - especially the ones that block DC from the grids of the output valves. They will need replacing with modern plastic film types. I generally fit the yellow Vishay 1813 types (that used to be branded as ERO / Röderstein) as replacements. Edited by madboffin - 22 July 2020 at 11:07pm |
GAZ.
Old Croc Joined: 16 January 2007 Location: Hertfordshire Status: Offline Points: 2433 |
I know they generally fetch an obscene amount of money!
I have got something that my mate is after at the moment, I might see if he wants to do a swap! Either way I’ll get it off him at the weekend or maybe sooner if I end up in the area, and get it on the bench in my lockup. I’ll post some pictures as I’m sure a few people here will be interested! I’m curious as to what I’m going to find, it might have been serviced in the past, or I might be the first to touch it after many decades. Quite looking forward to working on it actually |
100% Earth Moving Bass
odc04r
VCalve amps are pretty straightforward to work on in general, simple circuitry if you understand it. Just observe all the usual HV precautions and you'll be fine. I like to dedicate a meter to monitor only the B+ voltage which is never disconnected, then I use others to probe. At a glance you know if it is live, helps concentrate the mind.
studio45
+ 1 I actually love working on valve amps, they are so much easier to understand than transistors.
Of course, these are the rose tinted spectacles of someone who hasn't had a shock off the B+ yet; I expect that changes one's views on the matter!
I like odc04r's dedicated meter idea. I always work in thick rubber gloves, using only one hand as much as possible. That way even if a sharp live wire pierces the glove, I'm not getting a shock right across the chest. Plastic chopsticks are very useful to tap around the circuitry and see if anything is loose, you can even tape your meter probes to them so your hands are as far away from the angry pixies as possible. Fixed an Orange bass amp head last year - six hundred and ninety English volts on the output tube anodes - CRIKEY! |
Chris I Rockas
Registered User Joined: 16 April 2007 Location: United Kingdom Status: Offline Points: 75 |
TL12 refurb, also worth watching.
Think you can, you will. Think you can't, you won't.
odc04r
That is a healthy B+, I've only built up to 400V so far - which I had zero problems with but it was enough for me. Not that you should take shortcuts with any HV but in the worst case from 400V I am fairly confident I would live to be angry with myself for being an idiot. 700-800V starts to become somewhat more unknown territory, and you have doubled the chance of it jumping a gap too. Zero room for mistakes there. |
Andylaser
Registered User Joined: 16 April 2010 Location: Southampton Status: Offline Points: 300 |
I had my mind concentrated by a belt of 370VDC which sent me spinning across trhe workshop on my office chair.
"music so loud, that if we move in next door to you; your lawn will die" - Lemmy
BJtheDJ
Young Croc Joined: 28 November 2012 Location: Bristol Status: Offline Points: 886 |
Yep.. DC bites a little harder than AC
Edited by BJtheDJ - 27 July 2020 at 8:20pm |
It's a difficult choice, would you rather have:
A: A vegan son. B: An OnlyFans daughter |
GAZ.
I got a quick look at the inside of the valve amp at the weekend.
One of the valves is broken and needs replacing, possibly 2. The big square capacitor doesn’t appear to belong in there... |
madboffin
Very nice, and all original apart from the paper block capacitor. So nice that it would make a lovely museum piece if left untouched. But I'm sure we'd all rather see (and you'd rather hear) it working to original spec or bettter.
You can expect most of the carbon comp resistors to have drifted up in value. Depending on where they are in the circuit, some will need replacing with modern film types - unless you want to go all the way and replace the lot. The metalpacks, although very high spec when new, are almost certain to be leaky. Don't be tempted to replace with identical new old stock types. Although the audiophools drool over them (with prices to match), even NOS ones are often leaky. Modern MKT 1813's are the way to go. If you don't like the bright yellow colour you can use them to re-stuff the metalpacks although I wouldn't go that far... If you intend to sell the amplifier after refurb, keep all the replaced components in a bag and send them out with the amplifier, some buyers like to see the originals (no, I don't know why either...). |
APW
I was given a Quad II monoblock years ago that was just missing the GZ32, it still has its original GE KT66s and is in fairly good cosmetic condition…. it’s currently in a cardboard box under the bench in my workshop…. One day I’ll get around to restoring it. |
