Vista wifi issue |
dwsound
Young Croc Joined: 06 February 2008 Location: United Kingdom Status: Offline Points: 1069 |
Posted: 17 January 2010 at 4:59pm |
scratching my head on this one
my wifi on laptop keeps disconecting at home and i have no idea- i have full service around my flat so its not that. any ideas? dan |
chilli
Old Croc Joined: 28 July 2004 Location: United Kingdom Status: Offline Points: 1676 |
do other wireless devices stay connected? what make is the router?
Money can't buy you happiness, but it can allow you to be miserable in comfort.
dwsound
Belkin N series - doesnt do it all the time, just at random times
mrchay
Young Croc Joined: 29 September 2008 Status: Offline Points: 565 |
its possible someone next door has one of those routers that hogs as many of the 16 allocated frequencies as possible in order to provide them with extra speed..
should certainly try a different router for a bit, consumer level wifi is generally barely up to any spec |
Humble Tafari
Registered User Joined: 26 November 2006 Location: United States Status: Offline Points: 562 |
did you try experimenting with operationg your router on different wireless channels?
Is the wireless located near any strong magnetic devices (fridge/tv/etc..)? Is there any heavy outside work taking place in your area? Does it happen during certain times of day, for the exact duration of time? Answers may help us pinpoint your issue. Respeks
b3n
Registered User Joined: 28 September 2008 Location: Brighton, UK Status: Offline Points: 222 |
Download netstumbler and see if any other access points are broadcasting on the same channel as you. If so change your channel in your router config.
http://www.stumbler.net/ |
Matrix XP3000H, Thomann TA1050, Peavey CS1400, QSC RMX1450
2 x Eminence Kappa and PSD2002 loaded x15's 2 x SN-15MB and BM-D450 loaded X15's 2 x V18-1000 loaded 1850's Behringer DCX2496 |
