  New Posts New Posts RSS Feed - Voice coil unwound!
Voice coil unwound!
Grubbah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grubbah Quote  Post ReplyReply Direct Link To This Post Topic: Voice coil unwound!
    Posted: 09 March 2016 at 8:40pm
I've come across an 18" where if you look through the vent holes in the rear of the magnet you can actually see the voice cool has come completely unwound! If you shake the driver it sounds you're tipping a bag of skittles up side down
Is this too much average power level abuse or potentially mechanical failure of sorts?
madboffin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote madboffin Quote  Post ReplyReply Direct Link To This Post Posted: 09 March 2016 at 8:48pm
If the wire has fallen off the coil former, it usually means the glue has failed due to overheating, caused by too much sustained power.
Sometimes it's a manufacturing defect, i.e the glue wasn't properly cured.
mark_in_manc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark_in_manc Quote  Post ReplyReply Direct Link To This Post Posted: 10 March 2016 at 2:14pm
Sounds like overheating to me too.  A pure mechanical failure might result from momentary excitation by a very large, impulsive signal which did not contain enough power to heat the coil up - but you'd not expect this to part the coil from the former.  It might part the former from the cone!  :)
This page was generated in 0.082 seconds.
