  New Posts New Posts RSS Feed - Void 18-1000 How many watts amp
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 29 January 2006 at 8:30am
also wot about 1kw per box [void driver?] just wondering cos a mate gona run 4 and hes thinking of getting a 4 kw amp [he hasnt asked about it i was just wondering wot to expect wen i next here his system]
Mal X View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mal X Quote  Post ReplyReply Direct Link To This Post Posted: 29 January 2006 at 1:08pm
ok this is how it used to work for me. The V18-1000 is a beast and sounds awsome in an X1. 1Kw of juice per box is enough to make it sing very nicely indeed.
Mal, how loud was that!!!!!!
Dom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dom Quote  Post ReplyReply Direct Link To This Post Posted: 29 January 2006 at 5:12pm
To be honest for all this talk of PD's needing 2k to get moving, I think you'd be hard pushed to tell the difference between X1's loaded with voids and PDs as I have X1s loaded with both and I've never stood there thinking that the PD loaded ones needed more power...
1kw will be fine I reckon.  You need to make sure you high pass with a pretty steep slope to keep the excursion within reasonable limits..
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 30 January 2006 at 8:01am
Did you ever get around to doing the SD18 version Dom?
How did it sound in comparison if you did?
Dom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dom Quote  Post ReplyReply Direct Link To This Post Posted: 30 January 2006 at 3:21pm
Yeah I have my prototypes (the X1 shaped X1s rather than the letterbox shaped ones) which are loaded up with SD18s.  Not had a chance to actually measure them to see if they play lower and flatter than the Voids or PD1850s (I guess they will as the modelled void is very similar to the reality of a measured void and the SD18 models better than either the void or the PD).  I'm also pretty sure Rog wouldn't recommend them if they weren't the dogs.  They sound fine.  But so do the voids and the PDs.
Am having a lockup clearout in the next few weeks and the prototypes will be up for sale if anyones interested in a pair of original spec X1s
Personally I'm going for PD1850s for the proven reliability and consistant availability.
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 31 January 2006 at 9:09am
Hmmm, i may know someone who might, before he builds some LS1200 clones....
Fushion Julz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fushion Julz Quote  Post ReplyReply Direct Link To This Post Posted: 01 February 2006 at 9:14am
Dom..how much, fella?
Might be interested in those...
FUSHION SOUNDSYSTEM
www.fushion.org.uk
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 01 February 2006 at 1:20pm
Did you do the prototypes in MDF Dom?
whitehousejamie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whitehousejamie Quote  Post ReplyReply Direct Link To This Post Posted: 01 February 2006 at 2:13pm
May be interested in some boxes, let me know what you have and how much.
Cheers
