Void Digidrive V2 - Firmware |
Post Reply | Page <1234> |
Guests
Guest |
Yes, it reads the device-id from the unit, then its just a need to rebuild the config with the obtained device-id and rename the latest firmware for the device to match. it took me a couple hours to figure it out now i can update to latest firmware and software easily
michmich
New Member Joined: 28 August 2017 Status: Offline Points: 6 |
I had the same problem, it would only install on the latest dev build of wine or on my old win 7 laptop, old stuff :)
here is a link to the zip file (hopefully I got the sharing permission right) : https://drive.google.com//d/0B7pe58AQE_nlX3g3ZGpkbWR4RTQ/view?usp=sharing - https://drive.google.com/file/ |
Guests
Guest |
okay, your device id is 15_1_13
i will modify my setup and send you a zip later this evening. |
michmich
thank you so much mate, there is so little official support for old AllDSP oem products, you'll be doing me a huge favour !
krestudon
Registered User Joined: 23 August 2011 Location: Madrid Status: Offline Points: 32 |
Hello,
I have a livedrive v2, which is also an alldsp unit. Mine is running following versions: SW: 3.4.2.15011 HW: 4.9.3 Didn't managed to get the device ID, where are you getting it from? i'll download the alldsp software and to figure how is it checking the hardware. |
Guests
Guest |
you can get it from later versions of the software via the about dialog, but first you obviously need to be running the later version - you can find it in the config file installed in the program directory, look for supported_units or similar
krestudon
I think i found it:
[ROOT] skin_path = skins build_number = 105316 about_text = Copyright (C) Void Acoustics 1_1_13 = Digidrive V2 title = Void Network Control Software ethernet_support = yes brand = Void default_skin = 111_0_0 1_1_31 = Livedrive V2 use_master_network_window = yes child_offset_y = 25 child_offset_x = 0 demo_password = Demo 1_1_2 = 1800B 111_0_0 = Digidrive V2 111_0_1 = Livedrive V2 supported_units = 111_0_0,1_1_13,1_1_2,111_0_1,1_1_31 Maybe i have to add "111_0_1" to the supported units on the new software config? as the "1_1_31" is already listed there.
krestudon
After i added that id to the config, it detects the livedrive on the main menu, but stays on "connecting..." forever.
Also tried updating, but it says "Erase failed"
Edited by krestudon - 29 August 2017 at 4:30pm |
Guests
Guest |
post your full config here
Guests
Guest |
ok if both of you that need help install this:
ftp://webdownloads:4AH2a2FA@ftp.monacor.de/DSM-26LAN/DSP_Controlle%20V_3_8_22.zip It's the Monacor version of the DSP software(which is latest and I found works best) I'll post up the changes for you both shortly
Guests
Guest |
okay michmich, once you've installed that software I outlined above, download this: https://ufile.io/7gg24
Then extract and merge the contents with c:\program files (x86)\monacor after that start the DSP controller and you should have latest software and be able to connect. you can then enter admin password (Ad_min from memory) to get access to firmware update menu check the front panel of the device to confirm firmware update if this works i'll do the livedrive v2 one for krestudon
michmich
it worked for me, freddy you are an absolute legend !
