  New Posts New Posts RSS Feed - Void Digidrive V2 - Firmware
 Post Reply Post Reply Page  <1 234
krestudon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote krestudon Quote  Post ReplyReply Direct Link To This Post Posted: 11 September 2017 at 9:20am
Did you know if theres any way to see which identifier the unit identifies itself?
I'll try a traffic capture later today, and see what goes on.
Thank you, Freddy
Guests View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 11 September 2017 at 9:23am
during my initial checks, i did wireshark the traffic going to and from the unit, but it appears not to be easily decipherable - i would need more units with different device IDs to be able to spot a pattern etc
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 21 September 2017 at 5:59pm
krestudon, I have managed to fix this problem. I now own a livedrive and had the same problem as you. the trick is to update the firmware first using the void install, then you can use the newer monacor control app.
so copy the matching dfi file from monacor to your void dfi directory, use void controller to log on, find enter password on menu and use Ad_min, then find update firmware, once done, you should be able to connect with monacor app
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 21 September 2017 at 7:12pm
Oops you need to rename the firmware file to match as well
Post Options Post Options   Thanks (0) Thanks(0)   Quote krestudon Quote  Post ReplyReply Direct Link To This Post Posted: 29 September 2017 at 9:22pm
That worked exactly as you said. Now its updated and it works with all software releases.
Thank you very much!
One more question; i've seen that the void version in Tools menu has a BGM player util, but haven't managed to made it work in any way. Have you used it?
The OEM, or Monacor versions, doesnt have it.
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 29 September 2017 at 9:52pm
Never used the bgm thing. Also 0_0_0 DfE file is an interface firmware update...use the newer app to update firmware again and check the about menu, if it says (OK) then you're on the latest
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2017 at 2:47pm
for all interested parties, there's new software and firmware on the alldsp site:
Post Options Post Options   Thanks (0) Thanks(0)   Quote krestudon Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2019 at 9:42pm
And a new one...
