VOID IN SUPER SCOOPER |
Page 12> |
Insomnia
Joined: 06 September 2005 Status: Offline Points: 1721 |
Topic: VOID IN SUPER SCOOPERPosted: 28 September 2006 at 7:07pm |
WILL THE VOID 18, GO DIRECTLY INTO THE 1850 SUPER SCOOPER? IM JUST ABIT WORRIED ABOUT CLEARANCE ISSUES WHERE THE MAGNET MAYBE TOO CLOSE TO THE PANEL COMING DOWN
Nigey-C
Joined: 06 February 2006 Location: Grimsby... FISH Status: Offline Points: 1342 |
Posted: 28 September 2006 at 8:42pm |
if it doesnt fit, couldnt you jus move the panel back slightly?
mykey
Joined: 18 August 2005 Location: UK/Indonesia Status: Offline Points: 9680 |
Posted: 28 September 2006 at 11:56pm |
or machine out a round recess
i had to do that for the Volt drivers to fit in scoops
Static Age
Joined: 14 November 2005 Location: Oxfordshire Status: Offline Points: 1652 |
Posted: 29 September 2006 at 12:09pm |
they do fit in ok, speak to abrupt on here he has super scoopers loaded with voids.
Tekasis
Posted: 29 September 2006 at 2:18pm |
I thought that board behind the magnet is at a specified distance from the front baffle board, so wouldn't moving it forward & backwards affect the sound & efficiency of the box ?
I got a box builder to try a volt driver in his super scoopr the other day & it couldn't fit.
The board was too near to the back of the speaker & touching, preventing it from fitting.
Cutting a recess in the board, doesn't that affect the sound ?
Suppose you cut a hole straight through it, that sureley must affect the sound.
Tekasis
Posted: 29 September 2006 at 2:27pm |
Abrupt, where are you mate ? we need some answers urgently.
Can I ask, the fella 'Dom' who's on here is that the same person who has the super scoopers on speaker plans projects loaded with PD850s ? (They look brutal)
Isn't the Void V-18 1000s an exact copy in size to the PD 1850s ? (Except the mounting hole where the Void is slightly larger).
Insomnia
Posted: 29 September 2006 at 7:04pm |
I think i can answer my own question
!! just checked both void and PD1850 measurements and they are both 187mm deep so the voids will fit into a standard 1850 super scooper and every other 1850 application no problem.
Tekasis
Posted: 01 October 2006 at 3:24am |
See the following:
Tekasis
Posted: 24 October 2006 at 9:18am |
Can I get a few answers on the following question please ?
What is the exact size of the hole (diameter) to be cut in the baffle for fitting a Void v18 driver ?
What is the exact size of the hole (diameter) to be cut in the baffle for fitting a PD1850 driver ?
DUBPLATE
Joined: 27 February 2006 Location: United Kingdom Status: Offline Points: 366 |
Posted: 24 October 2006 at 7:37pm |
cutting a hole in the panel behind the magnet would be the worst thing you could ever do to a scoop, draw a picture of a scoop side ways on showing the inner panels then draw lines showing the air being passed through both holes throat & the hole in back plate then you will see
i would be very surprised if it sounded good, & throat area would be messed up
what i would do in your position is get a baffle to fit over the front of the box to bring the magnet forward
mykey
Posted: 24 October 2006 at 11:49pm |
Tekasis
Posted: 25 October 2006 at 9:50am |
As I can't get no one to answer my question, I've been hunting round & found the details for the PD1850, but still can't find the measurement for the Void V-18 1000.
Page 12> |
