Void Inf 8 VS FFA, MC2, Powersoft |
Post Reply | Page 123 4> |
junoprobelaunch
Registered User Joined: 01 April 2018 Location: Devon Status: Offline Points: 298 |
Posted: 14 October 2018 at 12:34pm |
Hi Sorry for poking this So that leads me here. I have £1000-£1600 to spend on a second hand bass amplifier. Based on my needs, where should I turn. N.B: Weight of amps is, for me at least, a secondary consideration and I'd much rather lug a 40kg amp of pure bass power than a featherweight that pales in comparison. Edited by junoprobelaunch - 14 October 2018 at 12:35pm |
cravings
Old Croc Joined: 30 January 2007 Location: Ireland Status: Offline Points: 7439 |
rent some of the above amps for a play? see what you prefer yourself.
junoprobelaunch
I'd love to but in my area, equiptment rental is very limited. Not only that but I do not have a space that I could really do it because to get a feel for these amps I'd really want to crank them up.
levyte357-
IMHO, not enough for 1x really quality Lightweight to drive 6x 1500w cabs, or 2x quality heavyweights to drive 4x 1500w cabs each, with heavy sub material, without clipping, reliably.
You've spent money on drivers, why not also spend real money on bass amp? |
levyte357-
By experience, on 32A supply, with bass heavy material played, I've seen MC2 E90, FFA10, Powersoft K10, Crown Itech 8, Matrix XT10000, all struggle to fully power 6x 800W PD1850s, before clipping. |
junoprobelaunch
Quite simply because I'd like to still own a pair of kidneys :P 6, (and eventually more) is the end goal so at the moment one that can run 4 really well would suffice. Having said that, on the second hand market £1200 would get you an FFA 10K and the upper end of my budget would nab a K10 non-dsp (on a good day) - both amplifiers that should easily be enough to power the 6 Obertons.
junoprobelaunch
You're not the first person to say something along those lines haha. Honestly at the moment I'm very much leaning in favour of buying an Infinite 8 and then another it the future as it seems head and shoulders above what it's lightweight counterparts can do. Only reason I started this thread was because of a lack of actually useful comparisons between such amps.
nickyburnell
£1800 should see a pair of VZ5000 in good order? Here's one with a best offer No transformer available for Inf8 v2 anymore if it should die (I believe). |
levyte357-
I'm talking from practical experience, not taking manufacturer specs, as gospel. When you set sub HPF below 50hz, you'll notice given specs mean almost nothing. Few years ago, a member here posted he bought a Crown MA5000VZ, for £500 from Cash converters, and it out performed his Lab Gruppen 10K lightweight, at 4 ohm sub.. Something to consider, when taking manufacturer specs as facts.
junoprobelaunch
That sure is interesting but convolutes my ideas of which amp to get even more haha. Have heard good things about the 5000VZ but have you any idea how it stacks up against amps that are a little more renound for being good on sub?
junoprobelaunch
Thanks for that, definitely something to consider. Seems the only way to fix a bust transformer these days is to get it re-wound.
levyte357-
IMHO, only a madman would pay > £750 for MA5000VZ. If a person blows transformer in Inf8MK2, that person is inept, and should not be doing sound.
