Forum Home Forum Home > Buying and Selling > Wanted
  New Posts New Posts RSS Feed - Void Livedrive V2
Void Livedrive V2
bass*en*mass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 27 February 2018 at 3:42pm
Bump :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2018 at 3:03pm
and another shameless bump :)
Guests View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 13 March 2018 at 3:36pm
which one of these is yours?
2_1_10 = Prime Amp
2_1_1 = DXO24e
2_1_6 = DXO48PRO
2_1_7 = DXO88e
2_1_4 = DML22
2_1_5 = DXO26PRO
2_1_2 = DXO26i
2_1_3 = DXO26e
2_1_0 = DXO24s
2_1_8 = DXO48e
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 13 March 2018 at 3:38pm
also, is the psso in that list as well?
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 13 March 2018 at 4:56pm
only the dxo pro units and the prime dsp amp are alldsp based afaik.. we got dxo26/48pro, the psso ones are basically the same units as the omnitronics and work with the same software iirc (will check again asap), unfortunately the void livedrive units dont work with that software and vice versa..
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 13 March 2018 at 8:15pm
All of those above are from the AllDSP config. So they will all be AllDSP based. You just need to add a few lines to your config and copy some files, I'll let you know the process tomorrow
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 13 March 2018 at 9:50pm
ahh, ok, thought those cheaper units were chinese oems.. haha
look forward to your reply! cheers
