  New Posts New Posts RSS Feed - Void V18-1000 vs B&C 18TBX100 in superscoop
heavydub View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote heavydub Quote  Post ReplyReply Direct Link To This Post Topic: Void V18-1000 vs B&C 18TBX100 in superscoop
    Posted: 07 October 2020 at 9:37am
Hi to all SP members. A new member here.
I am building a 4 way sound system to play traditional foundation roots reggae but also modern reggae and digital dub. Sometimes I could play DnB too.
It's from a while that I'm reading and searching on SP forum. I would like to post here some screenshot I've collected that are specifically related to the subject of this thread. So I can show you what information I have already collected. Most of messages are from mr Levyte.
https://ibb.co/d4T94Pv -
https://ibb.co/V2Dzsy7 -
https://ibb.co/5645DwY -
https://ibb.co/16N6MSX -
https://ibb.co/Ph6nLKk -
https://ibb.co/StjtDj8 -
https://ibb.co/CBdcVW0 -
https://ibb.co/s9PYrwn -
https://imgbb.com/ -
I'm still undecided between Void v18-1000 and B&C 18tbx100. I am building 4x classic 18 mogale superscooper and I have to choice one driver to load them.
In particular I'm interested in opinions for each of this subject:
  • SPL (from comments around SP it looks like Void wins)
  • MUSICALITY (to me it's very important. I like the "dirty" sound of scoops, that wrap your body. But I also wants B-line to be very clear so that you can hear every bass note, not only in the upper bass but also in sub)
  • DEPTH what low frequencies can those driver reproduce with energy? I've read a message by Mr. Levyte on SP in wich he says something like "I would never HPF scoops to 30HZ cause I like them working at the end of night". So you cross them at 35? Very low notes are very important to me. As I stated, I would play traditional foundation roots reggae but also lot's of modern roots and digital dub.
  • DURABILITY it looks like 18tbx100 it's not very strong. Is it true? Is void known to be stronger?
  • PRICE Void costs about 110€ more than B&C according to best prices I could find in EU stores. Is there any quality reason behind this difference? 18tbx100 price is very attractive.
  • ...MORE If you think there's more to consider, please let me knkow.
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 07 October 2020 at 12:40pm
Would suggest for your purposes,
Build these Scoops, kindly provided by Mykey:
https://forum.speakerplans.com/fane-scaled-up_topic74640.html
Will work with large number of the best Scoop drivers.
Especially original version PD1850
Post Options Post Options   Thanks (0) Thanks(0)   Quote heavydub Quote  Post ReplyReply Direct Link To This Post Posted: 07 October 2020 at 12:51pm
https://forum.speakerplans.com/fane-scaled-up_topic74640. - https://forum.speakerplans.com/fane-scaled-up_topic74640.html
Thanks for  your suggestion mr Levyte.
PD1850 is too expensive. Why did you suggest the mykey design over original mogale superscooper design? Any particular reason? Could you please provide additional information in the comparison between void and B&C drivers? I know you tested lot's of scoops design and drivers in the last years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 07 October 2020 at 1:12pm
You can only get the PD1850 series 1 (Mk1 and Mk2) used now, they stopped making them years ago.
In UK, you can probably buy freshly reconed Series 1 PD1850s, for £280.
Suggest you forget all about the B&C 18TBX100 for your purposes, For years most Heavy Dub Sounds used PD1850s in Scoops similar to Mykeys.
Post Options Post Options   Thanks (0) Thanks(0)   Quote heavydub Quote  Post ReplyReply Direct Link To This Post Posted: 07 October 2020 at 1:22pm
Precision Devices, as you said, stopped making PD 1850. I would avoid used drivers. And I would like to be able to recone my drivers, if needed, in next years. So I'm not considering PD.
Why sould I forget 18tbx100 for my purposes? What can't 18tbx100 specifically do? Be loud? Reproduce low ends?
Anyway, I could get Voids. Do they sound musical? It's very important to me.
Also, before build any design, I would like to know how the sound this design produces changes. Specifically: let's say we have 4X superscoop and 4x mykey scoop, everything Void v18-1000 loaded. What difference there should be between the two stacks?
Edited by heavydub - 12 October 2020 at 10:58am
paulus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulus Quote  Post ReplyReply Direct Link To This Post Posted: 08 October 2020 at 2:04pm
get the voids , i used the B N C in small chamber scoops , just sound very regular untill they buckled v1000 sounds amazing in small chamber cabs
TRENDSETTER SOUND SYSTEM
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 08 October 2020 at 2:29pm
If dude has mind made up on Superscoopers, Voids would be one of the top  drivers in it.
However I think more drivers would work well in the Mykey Scoop.
Voids in Mykey Scoop would be real loud, louder than PD1850, but just need "few measures", to ensure warmth.
Sure a few 18sounds drivers, will pound in Mykey Scoop as well.
Tweeter_Box View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tweeter_Box Quote  Post ReplyReply Direct Link To This Post Posted: 09 October 2020 at 1:06pm
Void will be fine, its powerfull enough to work in most boxes without struggling
BUT
its easier to get recone kits for B&C from wat i remember
ALSO
youll likely be reconing B&C more oftem than Void if your playing hooligan dub !!
https://www.facebook.com/PurpleAudioRecords
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 09 October 2020 at 1:55pm
"B&C 18TBX100 is the most blown driver in Southall"
Wonder who said that !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote heavydub Quote  Post ReplyReply Direct Link To This Post Posted: 09 October 2020 at 3:36pm
BUT
ALSO
I have a friend that owns different kind of speakers from years. Not a sound system, I'm talking about 2 or 3 way audio systems mostly used for live events or techno dj set. He never reconed a driver in his entire life. He is very careful with limiters, clipping and he uses good quality amplifiers.
In SP I often read about the recone "problem". Why? I mean, why lot's of reggae/dub sound system owners, at a certain point needs to recone their driver?
I can understand that modern digital dub it's very heavy on low frequencies.. but if you are carefull with limiters you should preserve drivers life. Am I wrong? Maybe I'm not considering something?
Post Options Post Options   Thanks (0) Thanks(0)   Quote heavydub Quote  Post ReplyReply Direct Link To This Post Posted: 09 October 2020 at 3:40pm
"few measures"? are you talking about crossover points / eq?
and moreover: Which 18sound driver are you talking about?
Anyway, if so much people is happy with Void and superscooper, I think I could go with them. I just hope they will go low enougth. At what frequencies would you HPF 4xVoid in superscooper to find a good compromise between sub notes and overexcursion?
Thank you for your patience, I know I have lot's of questions
Edited by heavydub - 09 October 2020 at 3:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 09 October 2020 at 3:50pm
Very important question, not mentioned.
What amplifier do you intend to power 4x Void V18-1000s with?
