Void V18-1000 vs B&C 18TBX100 in superscoop |
Page 123> |
heavydub ![]() Registered User ![]() Joined: 07 October 2020 Status: Offline Points: 23 |
![]() ![]() ![]() ![]() ![]() Posted: 07 October 2020 at 9:37am |
Hi to all SP members. A new member here. I am building a 4 way sound system to play traditional foundation roots reggae but also modern reggae and digital dub. Sometimes I could play DnB too. It's from a while that I'm reading and searching on SP forum. I would like to post here some screenshot I've collected that are specifically related to the subject of this thread. So I can show you what information I have already collected. Most of messages are from mr Levyte. https://ibb.co/d4T94Pv - ![]() https://ibb.co/V2Dzsy7 - ![]() https://ibb.co/5645DwY - ![]() https://ibb.co/16N6MSX - ![]() https://ibb.co/Ph6nLKk - ![]() https://ibb.co/StjtDj8 - ![]() https://ibb.co/CBdcVW0 - ![]() https://ibb.co/s9PYrwn - ![]() https://imgbb.com/ - ![]() In particular I'm interested in opinions for each of this subject:
levyte357- ![]() Old Croc ![]() ![]() Joined: 27 July 2012 Location: UK, South East Status: Offline Points: 7422 |
Would suggest for your purposes,
Build these Scoops, kindly provided by Mykey: https://forum.speakerplans.com/fane-scaled-up_topic74640.html Will work with large number of the best Scoop drivers. Especially original version PD1850
Thanks for your suggestion mr Levyte. PD1850 is too expensive. Why did you suggest the mykey design over original mogale superscooper design? Any particular reason? Could you please provide additional information in the comparison between void and B&C drivers? I know you tested lot's of scoops design and drivers in the last years.
You can only get the PD1850 series 1 (Mk1 and Mk2) used now, they stopped making them years ago. In UK, you can probably buy freshly reconed Series 1 PD1850s, for £280. Suggest you forget all about the B&C 18TBX100 for your purposes, For years most Heavy Dub Sounds used PD1850s in Scoops similar to Mykeys.
Precision Devices, as you said, stopped making PD 1850. I would avoid used drivers. And I would like to be able to recone my drivers, if needed, in next years. So I'm not considering PD. Why sould I forget 18tbx100 for my purposes? What can't 18tbx100 specifically do? Be loud? Reproduce low ends? Anyway, I could get Voids. Do they sound musical? It's very important to me. Also, before build any design, I would like to know how the sound this design produces changes. Specifically: let's say we have 4X superscoop and 4x mykey scoop, everything Void v18-1000 loaded. What difference there should be between the two stacks?
Edited by heavydub - 12 October 2020 at 10:58am |
paulus ![]() Old Croc ![]() ![]() Joined: 14 December 2005 Location: SOUTH BIRMINGHA Status: Offline Points: 3049 |
get the voids , i used the B N C in small chamber scoops , just sound very regular untill they buckled v1000 sounds amazing in small chamber cabs
TRENDSETTER SOUND SYSTEM
If dude has mind made up on Superscoopers, Voids would be one of the top drivers in it. However I think more drivers would work well in the Mykey Scoop. Voids in Mykey Scoop would be real loud, louder than PD1850, but just need "few measures", to ensure warmth. Sure a few 18sounds drivers, will pound in Mykey Scoop as well.
Tweeter_Box ![]() Young Croc ![]() Joined: 23 June 2012 Location: London Status: Offline Points: 851 |
Void will be fine, its powerfull enough to work in most boxes without struggling
BUT its easier to get recone kits for B&C from wat i remember ALSO youll likely be reconing B&C more oftem than Void if your playing hooligan dub !!
https://www.facebook.com/PurpleAudioRecords
"B&C 18TBX100 is the most blown driver in Southall"
Wonder who said that !! ![]() |
I have a friend that owns different kind of speakers from years. Not a sound system, I'm talking about 2 or 3 way audio systems mostly used for live events or techno dj set. He never reconed a driver in his entire life. He is very careful with limiters, clipping and he uses good quality amplifiers. In SP I often read about the recone "problem". Why? I mean, why lot's of reggae/dub sound system owners, at a certain point needs to recone their driver? I can understand that modern digital dub it's very heavy on low frequencies.. but if you are carefull with limiters you should preserve drivers life. Am I wrong? Maybe I'm not considering something?
"few measures"? are you talking about crossover points / eq? and moreover: Which 18sound driver are you talking about? Anyway, if so much people is happy with Void and superscooper, I think I could go with them. I just hope they will go low enougth. At what frequencies would you HPF 4xVoid in superscooper to find a good compromise between sub notes and overexcursion? Thank you for your patience, I know I have lot's of questions
Edited by heavydub - 09 October 2020 at 3:43pm |
Very important question, not mentioned.
What amplifier do you intend to power 4x Void V18-1000s with? |
Page 123> |
