Void V18-1000 vs B&C 18TBX100 in superscoop |
Post Reply | Page <123 |
Author | |||
heavydub
Registered User Joined: 07 October 2020 Status: Offline Points: 23 |
thank you Ken for the information! As I told, I'm working hard on scoop bins now. In next months I'll find the best quality/price solution for the amp!
Thank you very much. I will experiment around hints all of you are giving to me
I could be wrong but from what I've seen, Powersoft X or K series are much expensive than Labgruppen FP. (if you consider specs-similar models of course). I'll let you know my impressions with Labgruppen FP 140000 in next months.
smitske96
Young Croc Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 1092 |
If someone here is after the smaller Infinite 7v2, i have one hear for sale in NL
heavydub
Finally I started building superscoops. After few days of cutting and thinking I have a question: the superscoop plan says that you have to use 5cm of polyester fibre in the panel back to the driver. But doing this will result in the void driver that touch and "press" the fibre. Is this normal and safe or am I missing something?
MartinKanan
New Member Joined: 06 October 2021 Location: copenhagen denm Status: Offline Points: 1 |
Is there anybody who have specs on v18-1000640 im curious to see if u can use it in a scoop the component is made for a 640 parafæex cabinet but some People say that it has better motor and better cooling .. Please reply any information is gladly recieved Kind regards Martin Kanan
