  New Posts New Posts RSS Feed - Volt Studio Monitor Build
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbl_man Quote  Post ReplyReply Direct Link To This Post Posted: 13 August 2017 at 2:28pm
A small spacer-washer behind the grills at each fixing screw should do the trick? Might only need 2 or 3 mm?
Thady Trá View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thady Trá Quote  Post ReplyReply Direct Link To This Post Posted: 12 September 2017 at 12:27pm
Could we get some cabinet dimensions?
vertx View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vertx Quote  Post ReplyReply Direct Link To This Post Posted: 12 September 2017 at 12:49pm
Cut list for 15mm ply:
Top & Bottom 4x 254mm wide, 298mm deep
Sides 4x 270mm high, 298mm deep
Back & Front 4 x 224mm wide, 270mm high
Edited by vertx - 12 September 2017 at 12:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thady Trá Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2017 at 2:01pm
Thank you so much! And when you say 4x do you mean 4 pieces like..
DMorison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2017 at 5:20pm
The cut list is for a pair of cabinets.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thady Trá Quote  Post ReplyReply Direct Link To This Post Posted: 13 October 2017 at 2:48pm
How big are the holes on front and back?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thady Trá Quote  Post ReplyReply Direct Link To This Post Posted: 13 October 2017 at 3:06pm
And what tweeters are they? Sorry if I'm asking too many questions!
Post Options Post Options   Thanks (0) Thanks(0)   Quote vertx Quote  Post ReplyReply Direct Link To This Post Posted: 13 October 2017 at 10:53pm
Have a look at the website it has all the details you will need
http://www.voltloudspeakers.co.uk/loudspeakers/cx2201/
www.instagram.com/translate.sound
Post Options Post Options   Thanks (0) Thanks(0)   Quote vertx Quote  Post ReplyReply Direct Link To This Post Posted: 22 November 2017 at 6:20am
I've recently bought a calibrated mic and tuned these for the studio.
I've measured each speaker separately and EQ'd flat as possible.
Below is the averaged response of both the left + right speakers after EQ, with Psychoacoustic filtering applied:
Looks and sounds quite good.
But when I turn the mic to the centre and measure both speakers at the same time, it looks different to the averaged response of the seperate left and right channels post EQ.
Would this be due to comb filtering or should I be raising at 10,000 ?
markie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote markie Quote  Post ReplyReply Direct Link To This Post Posted: 22 November 2017 at 4:15pm
Here's a couple of pics of mine. Just chucked in in a couple of old orange boxes but they seem to work OK.
