  New Posts New Posts RSS Feed - Voltage gain for TA2400
ZuluSoundsystem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZuluSoundsystem Quote  Post ReplyReply Direct Link To This Post Topic: Voltage gain for TA2400
    Posted: 28 April 2012 at 11:52am
Yo, in the manual the voltage gain just says 91x standard.......wtf does this mean? what is standard.....im under the impression its about 42dB...but not sure
hemp much appreciated, cheers
For Rinseout Junglist Dub
http://soundcloud.com/warrior_zulu_soundsystem
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZuluSoundsystem Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2012 at 12:08pm
help, not hemp...!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2012 at 12:56pm
The easiest way to find out may be to measure it. Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZuluSoundsystem Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2012 at 1:07pm
And how would that be done? would i use a voltmeter or summat?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZuluSoundsystem Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2012 at 1:11pm
i think its a german thing, cos i used to have a berry europower and it said summin similar
Spartan Audio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spartan Audio Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2012 at 4:37pm
input sensitivity 0,775V,
http://www.spartanaudio.co.uk
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZuluSoundsystem Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2012 at 5:07pm
thats the voltage for 0dB from a mixer, I'm after the amp's voltage gain
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2012 at 10:45am
Yes, and some sort or signal generator. Inject around 1V into the amp and measure the output. If you don´t have a generator you could use 50Hz from the mains (Smile) with a small transformer, say 6V or 9V (raw AC, not rectified) - and a couple of resistors to divide the voltage, eg 10k and 1k.
Formula is simple:
Voltage gain = 20 x log(Vout/Vin) in dB´s
VentureSound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VentureSound Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2012 at 12:57pm
If the manual says its 91x, then that's 39.18dB voltage gain. There are lots of calculators on the web, just google it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZuluSoundsystem Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2012 at 2:49pm
safe nice one dude, cheers
