W8C ideal amp |
adamb00m
Joined: 05 February 2021 Status: Offline Points: 75 |
Topic: W8C ideal ampPosted: 17 February 2026 at 9:07pm |
Hi all,
I have a wavefront system (6 W8C, 12 WS218X). Processing / Amp racks (X 2 of these) - Linea Research ASC48 - Jam B8 (channel A runs 12”, B runs 6” and D runs 1” with channel C unused) - I run 2 or 3 W8C on this configuration per amp - so 8ohm 12” ~1100w, 16ohm 6” ~550w and 16ohm 1” ~550w) - the ASC48 limiters and gains are set well and they never sound stressed, even at full chat. - Jam Q10 x 2 running one WS218X per channel (~2200w per box. / 1100w per driver)… 2 spare channels for W3P fills as required. I know they aren’t the last word in amplifiers, but I am honestly impressed by them in general - huge bang for buck and really don’t sound bad with very good noise floor & zero hiss. Having said that… I’m considering upgrades (I have just ordered 4 Admark AD442s for the bass end). The B8s running the W8Cs sound pretty damn good to be fair, bags of headroom - but I wonder if there is anything better… I do want to stick with class D (weight) and 4 channel, but can be 2U. Also, don’t want anything with a DSP that could add latency. Options:
Any suggestions? Am I just being a rack tart? I can’t afford new powersofts - and the above roughly come in under £2k each.The systems genuinely does sound super clean as-is, with loads of headroom on the W8C - the subs can definitely deliver a bit more, hence the order of the Admarks for that role. Edited by adamb00m - 18 February 2026 at 2:35pm |
KDW32
Joined: 09 April 2010 Location: Green Hell Status: Offline Points: 770 |
Posted: 18 February 2026 at 11:18am |
I have not used one of the Jam amps. I have used FFA 6004 many timeson the bigger W8 and they sound fantastic. That is with dB mark xca+ so not as good as your Linea. See if you can borrow an FFA.
Edited by KDW32 - 19 February 2026 at 12:09am |
adamb00m
Posted: 18 February 2026 at 12:40pm |
That was the other option I was looking at that I forgot to add to the post - but would prefer one of the ones Alf Ligwa sold with the black face (because I'm a rack tart and pink would clash).
Edited by adamb00m - 18 February 2026 at 12:41pm |
jacethebase
Joined: 23 September 2009 Location: Somerset Status: Offline Points: 5837 |
Posted: 18 February 2026 at 9:02pm |
We had great results with FFA on our wavefront with both XTA & Lake.
www.stage2sound.com |
adamb00m
Posted: 19 February 2026 at 7:15am |
Hi Jase, as I’m local to you… don’t have an FFA 6004 I can try do you?
jacethebase
Posted: 19 February 2026 at 3:28pm |
At the moment yes but they are in the Enlightened Auction that ends next week so you could test it over the weekend if you wanted.
adamb00m
Posted: 19 February 2026 at 5:27pm |
Wicked!
I’ll give you a call tomorrow.
