Weird sound coming from driver |
Piato75
Registered User Joined: 16 May 2022 Location: France Status: Offline Points: 15 |
Posted: 10 April 2023 at 12:37pm |
Hello,
There is a weird sound coming from my Void V18 Here a video showing the problem : https://www.youtube.com/shorts/H9QmoZmbCS0 There is a "Tic" as if something is touching the cone or suspension, it doesn't seem to be coming from the voice coil but rather the suspension, when I lightly touch the right area, the "tic" disappears has anyone ever had this problem?
csg
Have you checked the spider? If it has split or has come loose this could be the culprit.
Another silly one, with the cab in the box is the feed in cable held away from the back of the cone?
Piato75
The spider looks fine, but the Void is a two spider driver so it could be the first one which I can't check.
The driver is out of the box for almost a year now but the feed cable didn't touch anything when it was mounted
Piato75
Could it come from the suspension which is a bit dirty ?
Edited by Piato75 - 10 April 2023 at 2:03pm |
Conanski
Are the tinsel leads riding on or touching the cone?
Piato75
It turned out to be the suspension, I took it off completely and glued it back on properly and the noise disappeared
Edited by Piato75 - 14 April 2023 at 1:32pm |
