  New Posts New Posts RSS Feed - Wharfedale wx8 Ohms Specs
JAH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JAH Quote  Post ReplyReply Direct Link To This Post Topic: Wharfedale wx8 Ohms Specs
    Posted: 08 November 2017 at 8:27pm
Can somebody help The specs to this amp seem not to be correct as most amps that operate from 8, 4 & 2 ohm range have quite an increase in the RMS and watts the lower the ohms go. Here is an example of Crown amp which runs at 8,4 & 2 ohms.
Here are specs of Crown xls2502 Amplifier
Crown Xls2502 Power Output specs:
2 x 440 Watts (8 ohms) Stereo
2 x 775 Watts (4 ohms) Stereo
2 x 1200 Watts (2 ohms) Stereo
Here are the specs to this Wharfedale WX 8 amp. I think the 2 ohms spec rating must be incorrect can somebody help? At 2 ohms the rating only jumps by 40 watts this cannot be correct. Most amps increase considerably more in watts the lower the ohms specs go.
Can somebody help what would the Correct wattage at 2 ohms be for this amp. It is also a really heavy amp which weighed in at almost 17KG without box. The weight specs are also incorrect at between 11.9kg with box on the Wharfedale user manual . The WX8 amp is nearly double the weight then the listed specs.
The listed weight specs are not near the correct weight making me think the 2 ohm specs are also incorrect for this amp also. Can somebody help. See the chart below for the incorrect 2 ohm specs for the Wharfedale Wx8 & WX12 amp.
Both Models seem not to go up by much in watts at 2ohms The WX8 goes up by 40 watts and the WX12 goes up by 100 watts at 2 ohm load. Can this be correct?
Could the Wharfedale specs be correct and some amps do not jump that much in wattage the lower the ohms go? Could it be the way the components are and the design etc?
WHARFEDALE WX8 AMP OUTPUT SPECS
8 ohms 500 Watts
4 ohms 800 Watts
2 ohms 840 Watts
WHARFEDALE WX12 AMP OUTPUT SPECS
8 ohms 700 watts
4 ohms 1200 watts
2 ohms 1300 watts
After viewing many pa amplifier specs which run at 8 ohm 4 ohm and 2 ohm load they all increase by about 300 watts the lower the ohms go as in the Crown amp specs example. What is easiest way to find out if the specs are correct?
Edited by JAH - 08 November 2017 at 9:14pm
DMorison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 08 November 2017 at 9:34pm
8 ohms 500 Watts
4 ohms 800 Watts
2 ohms 840 Watts
8 ohms 700 watts
4 ohms 1200 watts
2 ohms 1300 watts
Here are the specs of another Crown amp series for comparison, as you seem to think they're a useful benchmark:
Model 8Ohms 4Ohms 2Ohms
5000 1250W 2500W 2000W
9000 1500W 3500W 2800W
12000 2100W 4500W 3750W
So yes, it's entirely possible for an amp to deliver only 40W more at 2 Ohms than at 4 Ohms.
Re the weight, while it's disappointing the amp doesn't match the published claims, 17 kg isn't really that heavy - try carting around a rack of Crest CA17's, original Crown Macrotechs etc and you'll soon be glad it's only 17kg Wink
Lastly, how about contacting Wharfedale to ask them?
JAH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JAH Quote  Post ReplyReply Direct Link To This Post Posted: 08 November 2017 at 10:05pm
Strange how now now these Crown amps seem to deliver less wattage at 2 ohms. Havent tried Wharfedale yet. Just wanted a few opinions. Most of the amps i seen the specs of go up at 2 ohms in watts
Edited by JAH - 08 November 2017 at 10:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 08 November 2017 at 10:15pm
Running at 2 Ohms puts a lot more strain on the output devices and the power supply, which can shorten the useful lifespan of the amp. It also makes you much more liable to poor damping factor from the resistance of the speaker cables, and means that if you use it as your default modus operandi then you don't have anywhere to go as a backup option in case of one amp dying on a gig.
Therefore, it's not widely recommended to use it as anything other than an energency option, and manufacturers like Crown (and it seems, Wharfedale) are making more effort to optimise performance at higher impedances at the expense of 2 Ohm specs.
JAH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JAH Quote  Post ReplyReply Direct Link To This Post Posted: 08 November 2017 at 10:26pm
So the amp would have a longer lifespan if played at 8 ohms or 4 ohms instead of 2 ohms.
What is the advantages of 2ohms then?
If lifespan is a disadvantage at 2 ohms for amps
Conanski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Conanski Quote  Post ReplyReply Direct Link To This Post Posted: 09 November 2017 at 1:06am
Jah... what the specs for that Wharfdale are telling you in an around about way is that the amp really isn't designed to operate at 2ohms and given this is an lowend brand it's possible the thing would overhead and shutdown or simply blow up if you try to run it hard at 2 ohms.
The Crown iT isn't really designed to run at 2 ohms either but this touring level amp will handle it without shutting down because it has a ton of safety features built in to accomplish just that.
JAH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JAH Quote  Post ReplyReply Direct Link To This Post Posted: 09 November 2017 at 12:28pm
This Wharfedale also has the following safety features Thermal protect, Over/Under-voltage protect, Over-current protect, Output DC protect, Output short-circuit protect, Power on/off mute.
Are these just average specs or above average specs concerning safety features ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Conanski Quote  Post ReplyReply Direct Link To This Post Posted: 09 November 2017 at 2:40pm
Just average and they don't say anything about how the amp would perform at low impedances.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 09 November 2017 at 3:55pm
The advantage of being able to drive 2 Ohm loads is that it makes the amp more versatile.
Say you configure your rig so that normally you only load down to 4 Ohms. Then one day, an amp dies on you. You then have the option of doubling up the numbers of drivers per channel to at least get you through the end of the gig (albeit with slightly less power per driver) rather than having to shut down entirely.
If you had your amps loaded to 2 Ohms already, you wouldn't have that option.
