what amp? and mids? |
scott
Registered User Joined: 13 September 2006 Status: Offline Points: 4 |
Posted: 13 September 2006 at 10:59am |
i am making two hd15's with PD154 drivers. what amp should i use (budget) and what shall i do about high mids/tweeters, can iconnect house speakers???
thankyou
ceharden
Two HD15's on their own will not be particularly useful. You'll need to stack them together rather than one on each side.
To get the most out of PD154's you'll need an amp capable of supplying each driver with at least 6-800WRMS. General advice is just to buy the best amp you can afford. If you browse the forum there has been much discussion in the past on budget amps. You will need an active crossover to split the signal between the amp running the HD15's and the amp running your mid/tops. You need to supply more information about what you're doing. |
scott
i am going two make the two bins i said. i want a cheap amp that will power them both only. i was wanting to know if it was possible to connect the amp from my hi-fi amp for the mid range and tweaters and how?.
