  New Posts New Posts RSS Feed - What amp?
What amp?
nilspixel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nilspixel Quote  Post ReplyReply Direct Link To This Post Topic: What amp?
    Posted: 03 April 2021 at 5:37pm
Hello forum.
Given I have a mono system with one
Subwoofer
600 watts RMS
8 ohms
and one
Top box
165Watt RMS
8 ohms
powered by a 12V 90AH battery. Thomann recommends that the output Watt by the Amp should be larger then needed in order to avoid clipping.
I own a Pioneer GM-D8704, it spits out 2 x 300W bridged. That would work for the top box, but for the sub ??
What choice would you make? Go for 1-Channel Amp?
Conanski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Conanski Quote  Post ReplyReply Direct Link To This Post Posted: 03 April 2021 at 5:59pm
You got the amp so try it, if it gets loud enough you're good. A larger amp with double the power would only get slightly louder but might cut the run time in half.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nilspixel Quote  Post ReplyReply Direct Link To This Post Posted: 03 April 2021 at 6:15pm
Even so, I still risk clipping and damage to some components. Especially when I want to play loud ...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2021 at 7:28am
"What choice would you make? Go for 1-Channel Amp?"
Or something stereo that will give you around 1kW bridged. It seems simple enough.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nilspixel Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2021 at 11:33am
Like this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2021 at 12:59pm
Well - you really need a crossover as well. Or find an amp/s with filters on it already, eg at least a low-pass for the Tham.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Conanski Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2021 at 4:59pm
You'll damage components even faster with a bigger amp if you don't know enough to stop pushing when the amp is out of gas.
