What can I do with Elokance NEO 12 4 AL? |
Lucide ![]() New Member ![]() Joined: 29 January 2022 Status: Offline Points: 6 |
![]() ![]() ![]() ![]() ![]() Posted: 29 January 2022 at 11:12am |
Hi, I recently got given Elokance NEO 12 4 AL speakers and don't know what I can do with it. Any suggestion?
DMorison ![]() Old Croc ![]() Joined: 14 March 2007 Location: Aberdeen Status: Offline Points: 1527 |
Bit hard to be sure without a frequency response graph, but the TSPs I could find suggest general purpose bass-mid for a typical small to medium sized 2-way. I'm not at my PC right now but you could put the parameters into WINISD or similar to check suitable box sizes & tunings. A wild assed guess would be 25 litres tuned around 70Hz. You'll also need to find an Xmax figure to see how hard you can push it; I didn't see it in the specs I found which may imply it's not particularly impressive.
Hi, thanks for the reply. The resonnance frequency is 47Hz. Wouldn't it be best to match the box with it?
With Qts as low as 0.28, tuning to Fs will result in a response that starts falling off quite high, probably above 100Hz. Tuning above Fs helps fill in that dip.
Earplug ![]() Old Croc ![]() Joined: 03 January 2012 Location: Europe Status: Offline Points: 6765 |
How many do you have? |
Peter Jan ![]() Young Croc ![]() ![]() Joined: 16 December 2008 Location: Belgium Status: Offline Points: 1008 |
Seems like some B&C rip-off. Doesn't mean it's bad by definition, but a bit overpriced when compared with real B&C speakers.
5.2 Ohm DC resistance suggest it's an 8 Ohm speaker, not a 4 Ohm speaker, RMS power capacity double of AES... makes you wonder about the care that was given publishing those T/S parameters. If the given T/S parameter values are somewhat correct, that speaker is probably good for a 2-way top (with subs) or maybe monitor duty. It'll never be a sub monster, that's for sure. I've put it in WinISD (out of curiosity) and it does indeed look somewhat decent in a 25-30 liter BR cab with ~70 Hz tuning. Useable from 75-80 Hz and up, so could work fine with subs. Monitor duty ... not so much... drops off too fast when trying to get some lows out of it in a sensible size and respons gets nasty when trying to compensate with bigger net volume and lower tuning. And than it gets too big for a monitor anyway. Given the low(-isch) Q values, it might work in a low/mid horn, but I take it you're not exactly intrested in that ? |
Low / Mid could be great if that's the only thing I can do with it
Is the MHB-30 good for these speakers? Or is the frequency difference too much?
Two of them
