What can keep up with the X1? |
volcano ![]() Registered User ![]() ![]() Joined: 23 September 2004 Status: Offline Points: 106 |
![]() ![]() ![]() ![]() ![]() Posted: 09 October 2004 at 12:52am |
Will this work? I have 4 scoop bins (original 15" JBL with 2225 loaded) with 4 big JBL 2" Horns (2446 + 2390 slant plate) with 8 slot tweeters. Under each bin I would like to put a X1. So the X1 playing 30 to 60hz and the scoops taking it from 60. Do the scoops keep up? Will the X1 keep up? Any advice is welcom! Greetings |
Elliot Thompson ![]() Old Croc ![]() ![]() Joined: 02 April 2004 Location: United States Status: Offline Points: 5051 |
Hi. It depends on the type of music you are playing through your system. Its one of the reasons why Dub, always sounds good on Scoops, and, garbage, on Techno. Most systems are designed to offer the best possible sound, with a particular style of music. Best Regards, |
staiper ![]() Registered User ![]() ![]() Joined: 26 February 2004 Location: Croatia Status: Offline Points: 545 |
I do not think that scoops are good for upper bass range (I am using them crossovered NEVER higher than 120Hz) I am recommending to you to build some HD15-s and put them above your scoops (but phase cancellations become problematic but somewhat can be fixed up with good LMS) Enjoy, Stipe |
I like the sound of my scoops!! I use them up to 800 Hz and they sound nice. The reason I want to put the X1 under them is that I want to play louder with them (as they don't have to play under 60 or 80Hz anymore) and I would like some extra sub low (now I low cut the bins at 40 Hz, response of the bins are is -6 dB @ 45 Hz). I have no problems at all with the sound of the upper bass. I just dont know about maximum sound pressure levels of the two bins (btw, I'm going to use the void driver) cheers |
O yeah, we play dancehall, rub-a-dub, but also merengue, soukous, and also elektro, d&b, so, .... a bit of everything
You will definitely need the X 1 under those conditions. I see where you are heading with this setup. You may need to use your own judgement on this. If you need more extension, just add more X 1s. It really depends how much more extended bass you feel is necessary. There were a few Dancehall Systems in the states that used to use Six 18 inch Scoops with two Double 18's. Sounded far superior compared to operating Eight 18" Scoops. It will work. Best Regards,
JD01 ![]() Young Croc ![]() Joined: 23 August 2004 Status: Offline Points: 819 |
I think that one X1 to one 15" scoop will be more than enough. Those scoops don't have a very high SPL 1W/1m. Of course they can be used up to 800Hz, just like any 15" + HF box uses the 15" speaker. It's direct radiating above 150Hz..... and so the whole cab has only the effiency of a direct radiating top.... no prob for the X1.
