  New Posts New Posts RSS Feed - What cheap multimeter?
studio45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote studio45 Quote  Post ReplyReply Direct Link To This Post Topic: What cheap multimeter?
    Posted: 12 July 2017 at 3:43pm
I'm considering replacing my crappy failing multimeter with something a bit better, but as ever don't really have the budget for what the pros use.
I can get an old Fluke 25 on th'Ebay for £30 or thereabouts, or the 27FM for £60 ish. I believe these were very well respected in their day and sold for £200+ new.
Are these old meters still worth having, or would I be better off spending £30 on a new meter from eg RS Pro?
Just want to take a step up from £15 "approximeters" LOL
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 12 July 2017 at 10:40pm
It really depends what features you need, as in what you'll be measuring.
One option as a step-up is Amprobe, who share the same parent company as Fluke, although the products aren't necessarily related.
Post Options Post Options   Thanks (0) Thanks(0)   Quote studio45 Quote  Post ReplyReply Direct Link To This Post Posted: 13 July 2017 at 5:33pm
I just need a solid volt-amp-ohm meter for general use. I don't really need capacitance measurement or a transistor test, but being confident about measured electrical values would be nice.
Thanks for the tip about Amprobe, I hadn't heard of them :)
The question is really, has technology advanced to the point where a new £30 meter from a reputable brand will be more accurate and reliable than a 30+ year old Fluke 25?
DJ-Dulux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DJ-Dulux Quote  Post ReplyReply Direct Link To This Post Posted: 13 July 2017 at 10:43pm
I'm using some of the new low cost rs branded ones now, really good value.
Dupe...
Dupe...
Post Options Post Options   Thanks (0) Thanks(0)   Quote RoadRunnersDust Quote  Post ReplyReply Direct Link To This Post Posted: 17 July 2017 at 3:57am
If it's for Audio use then make sure you get one that's 'True RMS'. Meters that aren't are usually calibrated to approximate the RMS value at 50/60Hz and will give you really screwy readings for the Voltage and current of Audio circuits
Buying myself a TFL-760H... piece by piece >.<
