What compression driver? |
Page 12> |
JamesFlipside ![]() Registered User ![]() ![]() Joined: 14 July 2012 Location: London Status: Offline Points: 162 |
![]() ![]() ![]() ![]() ![]() Posted: 30 November 2012 at 10:02am |
What are peoples feelings and experience with different compression drivers?
I'm looking for a 1.4" driver to cross over with the mids at about 2k on quite a soft slope. My preference has always been Beyma generally but i've been looking at Faital Pro recently and they look pretty sweet! anyone use these? Also there's BMS but the only dedicated HF compression they do is Ferrite... Still though? J |
"DFA switch fitted"
Peter Jan ![]() Young Croc ![]() ![]() Joined: 16 December 2008 Location: Belgium Status: Offline Points: 1014 |
I have tried about every available driver from all brands on a variety of horns and still keep coming out with B&C. Though other brands have good drivers too, but B&C always comes on top especially in the 1" and 1.4" drivers.
B&C DE-900/910/912 is absolute first choice in 1.4" for me. Beyma CP-755/Nd or CP-755/Ti also real good sounding drivers, just less efficient than the B&C. I don't care what the spec sheets say, the difference is audible and shows clearly in measuring. |
OK fine but they only do one horn for 1.4" drivers and in need 60x40 dispersion
"DFA switch fitted"
You mean the ME90 horn ?
Hmm yes, but considdering the fact you are going to cross fairly high (~2k), there are other brands/models that could fit the bill. 18Sound, RCF, Beyma, BMS, ... |
Earplug ![]() Old Croc ![]() Joined: 03 January 2012 Location: Europe Status: Offline Points: 7100 |
Why not 2":
http://www.p-audio.co.uk/products/P-Audio_BM-D750_100W_2_inch_Throat_Compression_Driver.html Best value for money hf driver I´ve found. |
krazyneil ![]() Young Croc ![]() ![]() Joined: 06 December 2007 Location: Bolton ,lancs Status: Offline Points: 1206 |
a question why do you want to use an 1.4" comp driver when your crossing over that high ?
normally you use the bigger cd drivers so you can cross lower like 1.2/4 a good 1" driver would be more suitable i would of thought ive had lots of good experiences with b&c and bms drivers so there worth looking at
GOD TOLD ME TO DO IT !!!!!
Mircea Bartic ![]() Old Croc ![]() ![]() Joined: 18 February 2005 Location: Romania Status: Offline Points: 2581 |
USE P-audio BM-D740 it's the same driver with a 1.4" exit. Or see if you can get the P-audio SD-63BF Sounds really good ![]() Edited by Mircea Bartic - 30 November 2012 at 11:15pm |
king david ![]() Young Croc ![]() Joined: 17 January 2007 Location: italy Status: Offline Points: 1324 |
if you cross at 2khz, b&c de250 is a very nice driver imho
Tony Wilkes ![]() Old Croc ![]() ![]() Joined: 02 August 2004 Location: West Midlands Status: Offline Points: 4840 |
If it has to be 1.4" then have a look at the Faital HF144, but as been mentioned by others crossing at 2K then a good 1" will be suitable.
Tony
Edited by Tony Wilkes - 01 December 2012 at 12:15pm |
ceharden ![]() The 10,000 Points Club ![]() ![]() Joined: 05 June 2005 Location: Southampton Status: Offline Points: 11749 |
You can mix and match manufacturers for compression drivers and horns! In terms of horns, I cannot recommend the 18Sound offerings highly enough. As with all these things it comes down to how much you can afford to spend. You're unlikely to be dissapointed by any of the offerings from the big name brands. There's a reason why a lot of high end manufacturers have used B&C compression drivers for a long while. As has been mentioned, a lot of the P-Audio offerings are a good option if you can't justify the big money drivers. I've got some of the old SD-740's and am very happy with them. |
thepersonunknown ![]() Old Croc ![]() ![]() Joined: 25 November 2009 Location: Madrid Status: Offline Points: 1628 |
sorry for the hyjack, but which 1 or 1.4, 1.5inch comp horn combos can play at 135db cont between 3kish and right up to 20k reasonably flat.
budget is more or less unlimited (in a reasonable way). just nothing silly, like unobtanium diaframs and grey diamond and ruby push plugs, or much worse.... audiophile hifi prices with directional wires, geothermal phase alignment coupleing paint and uber highly gometrically semi sperical cupola shaped diaframs (which is obviously a vast improvement over domes, which use only one noun and no adjectives or adverbs). pseudo science comes at a price, but hey, its great for the pseudo inteligent pseudo work hard for their money... only explanation i can think of, but then again im obviously tho thick to understand the value of these innovations its not an an easy task. one option ive been weighing was to use 2 line array drivers, as a single comp which can do this seems a little elusive. perhaps ive been looking in the wrong places. extra points for non metalic diaframs. what do we think? cheers dave |
They keep telling me life is short, but its the longest thing ive ever done!!!
TENSiON ![]() Registered User ![]() ![]() Joined: 02 September 2012 Status: Offline Points: 279 |
3k-20k, 135dB continuous, single driver/diaphragm(diafram)? Pretty much none (I know of). Some of the BMS coaxials can theoretically do it, but those are technically 2 drivers/diaphragms (and for the price of 4 ![]() Hard to even imagine a single driver with 300W rating and 110dB+ throughout the whole range (3k-20k), or 150W/113dB for that matter.. It doesn't seem to be too much of a stretch though (3-4dB), so there actually might be something exotic out there, who knows.. Many of the large format drivers can do those 135dB(cont) usually between 1k-3k. The better ones maybe like 0.8k-6k at best, but that's about.. |
Page 12> |
