What do you think??? |
kddp90
Registered User Joined: 04 April 2021 Status: Offline Points: 10 |
Posted: 17 April 2021 at 2:43am |
I wanna know something before simulating this in HornResp, won't there be a cancellation of waves at the points I marked here in red, or since both drivers emit waves side-to-side won't those interfere each other?
Edited by kddp90 - 17 April 2021 at 2:44am |
Tinnitus Rex
Registered User Joined: 31 October 2020 Status: Offline Points: 286 |
Very probably. what is the rectangle in the lower middle?where is the exit?
"couldn't we just like... use headphones?"
kddp90
That's the exit...
APW
Young Croc Joined: 13 November 2012 Location: Kent, UK Status: Online Points: 1174 |
I thought the rectangle IS the exit port, regarding cancelation.... …. Yes and no!!! depends on the path length between the front and rear of the driver as this will determine the frequencies at which the waves emitted from the front meets the rear of the driver either in or out of phase. When the waveforms are in phase they will add, and when out of phase they will cancel. |
kddp90
Do you remember the exit of Shahinian ContraBombarde?
True, depends on phase, have to model it, I don't remember its source now, otherwise it should've been a lot easier...
No problems. Very old design. Your biggest issue would be having it entering through single entry doors.
Best Regards,
kddp90
That big...???
The benefit of large horns is fewer harmonics dominating the overall sound. Small horns are prone to excessive harmonics which is why, many do not like the sound of horns. On the flip side, smaller horns sound louder to many due to a high amount of harmonics. One can look at it as distortion. The more distortion added, the louder the sound perceives to the average individual. With the exception of no sealed enclosure, that design is a very large Cerwin Vega L 36 (There were companies that made a double version to it). With the loudspeaker not being restricted by the small sealed enclosure, the loudspeaker has the capability of producing lower notes and using a partial part of the horn's pathway to amplify those lower notes. Just remember simulators cannot estimate harmonics. That is something you will need to measure yourself once you design the box. Best Regards, |
kddp90
Thanks for this advice, but if simulators can't how to estimate harmonics then and would you believe all kinds of horn-loaded enclosures add some color to the original bass (cos I usually don't prefer any color)...?
