What flat-sounding speakers to buy for sound thera |
Post Reply | Page <12 |
Author | |||
csg
in this circumstance i would stick with the Onkyo amp and use passive speakers - to use active, you will need some kind of mixer to easily control level / volume, and to get one as quiet as the pre-amp stage in the Onkyo you will need to spend a bit of money.
There are a plethora of options available -lower end, small hifi speakers are generally tuned to sound "nice" with a small bump in the LF and HF response so i would stick with something studio related, or a hifi box made from a studio speaker supplier. If your budget would run to it, something from ATC ( SCM7 would be perfect) or one of PMC's smaller options would be perfect.
edboom
Registered User Joined: 13 May 2011 Location: manchester Status: Offline Points: 48 |
Consider the effect the room will have on the freq. response. Wouldn't it make more difference than the type of speaker? I'm sure that eq will have to be applied to make the speaker/room combo flat, so is it totally critical that the speaker be flat?
JonB67
Tannoy reveals can be had for peanuts on ebay and gumtree.
Whats the material being played?
quick_frog
New Member Joined: 19 August 2017 Status: Offline Points: 6 |
Thanks.
Thanks, yes, the room might have a bigger impact, but I still aim for the flat frequency response of the speaker.
The sound of sea waves or akin to that. Edited by quick_frog - 14 June 2018 at 9:09am |
dylan-penguinmedia
Old Croc Joined: 14 April 2011 Location: Brighton Status: Offline Points: 4576 |
Unless the source material is EQ’d to suit the system, I can’t see how any adjustments can be made with a hifi amp and a pair of passive monitors...
quick_frog
The source material will be EQ’d.
dylan-penguinmedia
in that case, choose any half respectable speakers, as you’ll be correcting speaker and room response peaks and troughs anyway...
Xoc1
Registered User Joined: 15 October 2012 Location: Devon UK Status: Offline Points: 397 |
So what is the background level that you are going to start from in DB and what sort of distance are you likely to be from the speakers? To keep within the output of the amplifier you have chosen the background level would need to be less than about 0.02 watts to achieve the 34db increase 1 watt + 34db = 2512 watts...
