What grade of ply for amp rack wheelboards? |
Soundscape ![]() Registered User ![]() ![]() Joined: 09 March 2008 Location: United Kingdom Status: Offline Points: 412 |
![]() ![]() ![]() ![]() ![]() Posted: 21 November 2020 at 5:01pm |
Greetings all,
I'm looking for the grade of plywood which is normally used to make wheelboards. It doesn't need to be birch, that's overkill and too expensive. Deffo not MDF which clearly isn't ply anyway... What have members used previously? Can you point me at the right type please? Cheers
I-shen Soundboy ![]() Registered User ![]() Joined: 21 December 2016 Location: Big Smoke Status: Offline Points: 361 |
A recently made 5-Star Cases board uses black stained 12mm hardwood throughout plywood (as opposed to mere hardwood faced). No complaints with the quality, I added a coat of varnish for longevity. I use 18mm birch ply for my own dolly boards and wheelboards, then warnex and griptape. If you've got speaker plywood lying about, buying cheaper wood for one job isn't such a saving.
Edited by I-shen Soundboy - 21 November 2020 at 5:40pm |
dj jammin ![]() Young Croc ![]() ![]() Joined: 10 April 2010 Location: southampton Status: Offline Points: 735 |
B&q or wickes 18mm ply will be fine for the job of wheel boards etc.. cost around 35 a sheet but they do cut it up for free if they have a saw at your branch.. made my current amp rack from 12mm cheapish ply braced and reinforced at the corners/joins/handles etc.. has been great so far and really light without the amps in it..
Reverence Sound system
www.mixcloud.com/B1_Jams/ |
mk2_ginger_biscuit69 ![]() Old Croc ![]() Joined: 03 November 2008 Location: Brighton Status: Offline Points: 7781 |
might get away with shuttering ply from a builders merchant. the last 12mm stuff i bought was about £12.50/sheet. Probably the same kind of grade B&Q etc sell as 'ply'.
jacethebase ![]() Old Croc ![]() ![]() Joined: 23 September 2009 Location: Somerset Status: Offline Points: 5562 |
18mm birch is the only option in my eyes.
www.stage2sound.com |
Robbo ![]() Old Croc ![]() Joined: 05 December 2005 Location: Shropshire Status: Offline Points: 4086 |
I always used to coat our wheelboards in a few coats of matt varnish as it gives them good strong protection and also stops the edges from splintering and causing injuries when stacking cases.
snowflake ![]() Old Croc ![]() Joined: 29 December 2004 Location: Bristol Status: Offline Points: 2594 |
i'd leave at least one side not black. bit of a trip hazard in poorly lit places otherwise.
Boxes-R-Blue ![]() Registered User ![]() ![]() Joined: 11 December 2018 Status: Offline Points: 111 |
Yep...
given the cost of 4 castors, anything less is a joke! |
