what midtop cabinets are these? |
mikelink
Joined: 21 November 2012 Status: Offline Points: 63 |
Topic: what midtop cabinets are these?Posted: 05 September 2015 at 1:49pm |
hi, a friend of mine got these 2 midtops, http://imageshack.com/a/img540/2366/NuzXoT.jpg
loaded with a B&C 12cx32 for the low section and a eminence psd2002 hf driver. on the back there is a px2 3k5, http://imageshack.com/a/img537/6241/IKBIwY.jpg isn't this too high for crossing a 12 driver? maybe this is for the hf driver and some tweeters? Edited by mikelink - 05 September 2015 at 1:57pm |
lickweed
Joined: 02 May 2009 Location: leyton Status: Offline Points: 2525 |
Posted: 05 September 2015 at 2:14pm |
From memory 12cx32 is a coaxial
http://www.liquidsound.co.uk/
mikelink
Posted: 05 September 2015 at 4:44pm |
yes, they're coaxial http://www.bcspeakers.com/products/coaxial/archive/12cx32
is there any difference using a coaxial driver instead of a normal one in a horn? |
mikelink
Posted: 07 September 2015 at 1:45pm |
do you think i can use only the lower section of the coaxial driver or it will cause any problem? because i noticed that the high section cable connectors are missing
njw
Joined: 26 March 2010 Location: S. Wales Status: Offline Points: 2700 |
Posted: 07 September 2015 at 7:20pm |
I would probably do that anyway as I'm not sure a co-ax driver would work in horn, also, I'm intrigued, when you say the cable connectors are missing on the hf do you mean there are no connections on the driver itself? It sounds like are no diaphragms in them if that's the case.
mikelink
Posted: 09 September 2015 at 12:12pm |
yes, they're missing the diaphragms, i think i will try them active iin the next days, the passive crossover has been modified and some capacitors are missing
Edited by mikelink - 09 September 2015 at 12:13pm |
