What plan for single pd186 |
Page 123> |
Jarba ![]() Registered User ![]() Joined: 11 November 2021 Status: Offline Points: 23 |
![]() ![]() ![]() ![]() ![]() Posted: 03 May 2022 at 8:25am |
Hey, I have a single pd186 that we’re gonna use in a small room. The room is about 5 metres wide and 4 metres long. I’ve already got a pd186, but I haven’t built a box for it. We don’t have the budget to get anymore drivers and amps, so the build would be for a single driver. Does anybody have any suggestions? I was thinking of horns, but heard they shine when played with 4 or more.
Edit: We’ll be playing techno, dub and deep house. Edited by Jarba - 03 May 2022 at 8:56am |
sarsen1 ![]() Registered User ![]() ![]() Joined: 01 January 2016 Location: Bristol Status: Online Points: 77 |
B and C Sub 18 : 18-SUB Model (1) (toutlehautparleur.com)
Remember plans are for internal measurements and using 19mm ply, change to 18mm and add some bracing. B&C sub 18's - Speakerplans.com Forums - Page 1 Thread here on 186 in sub18. Search around more for some build pics for bracing and construction.
Do you think the 184 sub would be a good alternative?
levyte357- ![]() Old Croc ![]() ![]() Joined: 27 July 2012 Location: UK, South East Status: Online Points: 7448 |
The Original MK1 PD186, was great in this design. Does the OP have original PD186 or later version !? Not sure if later versions of PD186, will work as well, in same cabs, as the original.
I believe it’s the original version
pd186 is suitable driver for the 184 cab but if you want low notes, are using in a small room and aim to only build one I would personally go for a reflex option such as sub18.
If you did want to build more boxes to match in future and use the system outside or in a larger venue, then 184 could be an option. Although some might say that due to the 184 design being over 20 years old you might be better off looking at something else. The answer is as always; it depends!
Would it be stupid to go with a 186 horn if we’re only gonna be using one? Or is there some other horns that would work alone?
I should also state that size doesn’t matter at all, it will be in one place and not moved around.
186 would be even worse in small room than 184 in my opinion, will not drop low at all and designed to be used in block of 4 or more. My experience of messing around different subs in my small 11ft by 21ft studio is that anything other than reflex sounds pants. If you want to build something more 'exotic' than reflex for the experience/looks/building a larger system in the future and don't mind that it wont sound great, then do it. If you want what will sound loudest and lower in a small space then go reflex. As mentioned above Mk1 PD186 sounds great in the sub18 plan and would provide more than enough bass to shake your room.
Yeah, the reason a horn is more attractive is that we have it in a reloop pa1600 box. The box is kinda designed like the b&c 18 and the measurements are 530x650x800mm. It’s not as loud as we want though, we want the bass to be much more physical. Maybe it’s the room that causes a lot of cancellation? I tested it just now super inaccurately, but it gets about 110db at 50hz with 800 watts. I measured it with my iPhone right where the opening is. I know the measurement is inaccurate, but isn’t this quite low? I used a peavey cs800 amp at max for the measurement.
Xoc1 ![]() Registered User ![]() Joined: 15 October 2012 Location: Devon UK Status: Offline Points: 292 |
Not 100 % sure what the Thiele-small parameters are for the old PD186 you have but I would expect 124 - 125 db 2pi in a reflex cabinet like the 18-sub reflex. So your 'measurement' is way off or you have a problem somewhere?
I’m not sure, the iphone should only be about 2-5 db off. I’m not sure what else could be the problem
Page 123> |
