What Power Distro Will I Need? |
Sam_Avantí
Registered User Joined: 04 November 2020 Location: Bristol Status: Offline Points: 21 |
Posted: 17 January 2021 at 2:17pm |
Easy crew,
Compiling a full MC2 amp rack. (1 x MC2 E90, 1 x MC2 E45, 2 x MC2 E25, 1 x MC2 E15) What type of mains cable do these amps have coming out the back? Trying to figure out what power outputs I need on my power distro... Cheers, Sam
Edited by Sam_Avantí - 17 January 2021 at 2:23pm |
Stay Toasty
Sam_Avantí
MC2 E15 not 155... Obviously lol
Stay Toasty
mk2_ginger_biscuit69
obvious solution would be to lookup the specs and see what their power draw is. For tidyness id simply stick them all on a powercon each and get a compact powercon distro. However, on the assumption this wont always go out where there's a suitable single power outlet, you need it to be adaptable to be able to take multiple power inputs to say spread it over 13A sockets. Every persons use is different, so how you rig your rack is going to be fairly unique to your planned uses. Quite a setup to be buying for a question like this? |
4D
one of these along with enough convertors to step up from 240v 13a plug to a 415v 32a socket would do the job Edited by 4D - 18 January 2021 at 2:54pm |
