What size Amp? |
Post Reply | Page <1234 6> |
Author | |||
Earplug
"They say 4ohm on them but did Konanski not mean that when you link 4x4ohm speakers in parallel the becomes 2ohm," Ok - then definitely 4 ohm. Then put them in series. 2 per side on the QSC. Basic maths:- - in series, 4 + 4 = 8, so each channel "sees" 8 ohm. - in parallel, 4 + 4 = 2. Not too good for the amp... Edited by Earplug - 09 December 2022 at 10:58am |
SnailSpace
Registered User Joined: 08 December 2022 Status: Offline Points: 221 |
Thanks! So when run in series at 8ohm per channel would I refer to the amps specifications/capabilities in ‘bridge mono mode’ or by saying each channel sees 8ohms do I refer to the amps capabilities in ‘stereo mode both channels driven’ so would I be looking at a amp with 1000w per channel in 8ohms in Stereo? I know this is basics but I’m in pre school here dispute being middle aged ha! Konanski also mentions: “Neither, get a small class AB amp in the 150-200w/ch range.” I’ve had a look at these and they are the small box amp things right? Could I not get a smaller rack amp with speakon and use a limiter on the crossover to protect them?
Edited by SnailSpace - 09 December 2022 at 11:30am |
Earplug
SnailSpace
“ the QSC amp you already have should be fine“
So are you suggesting I use the QSC GX3 I have for the PV’s x4 and find a smaller or similar size amp for the Jamo x4? And a small amp for Tweeters? Would it not make more sense financially to get a large amp for PV’s and so when I do get subs I could use it rather than have to sell off amps to fund future upgrade? PS I’m not looking to compete with larger Sound Systems out there and I’m not especially into rattling glasses off shelves. Until I started to swap out I had x2 150w 15” McKenzie, x2 150w HH Acoustic 15” & the x4 Jamos and another speaker top box - all going stereo through a speaker splitter which has a max of 150w per channel so that acted as protection for speakers and amp I presume. But it sounded clear, loud and bassy enough for a small space, infact I’ve used the Jamos in a larger venue and they more than filled it with a nice sound. Infact I met the fella who is the speaker designer for Q acoustics when I was a photographers assistant and he actually designed them and really rated them. Now I know they are 90s PA/DJ speakers but they will give me a nice sound for what I need. The whole reason I want to get off the ground on a budget is because there is a distinct lack of sound systems in my area and I want to learn and pass on what I learn, so somethings better than nothing in my opinion. I know that might upset some of the more purists who spend £5k upwards but personally I’m more of a DIY approach. I’d be more than happy taking what I have now to a venue but when I was given the PVs I thought they seemed like a decent addition in taking the next step! Edited by SnailSpace - 09 December 2022 at 3:24pm |
Earplug
No. Please refer to my first post in the thread:- "You need a 3-way crossover or DSP to split the system into bass, mid & top. The PLX3602 is fine to power the Black Widows. 2 per channel in parallel. The GX3 for the mid (Jamos). Again, 2 per channel in parallel. For the tops, you need to find another amp. Something around 200W per channel will be fine. Use the best quality drivers you have. Maybe the Altai? And throw away the piezos!! " And my mistake -- I thought that you already had the PLX, but the plan should revolve around the above. And the Peavey's in series, not parallel. Simple. |
SnailSpace
Thanks! Appreciate both of your patience 👍
I tend to agree about the Behringer it’s twice the price of a DBX 234 but suppose its a case of buy once instead of twice Edited by SnailSpace - 09 December 2022 at 5:01pm |
Conanski
Old Croc Joined: 26 January 2006 Location: Ottawa, Canada Status: Offline Points: 2545 |
The DBX234 is a very basic crossover only, you would need it plus a whole rack of gear to match what the DCX can do. The DCX is a fully customizable crossover meaning you can independantly set the type and slope of every crossover filter on each ouput. But that is just the beginning it also has.. - Parametric EQ on every input and output - Time delay and phase alignment on every output. - Adjustable limiters on every output. - Dynamic EQ on every input and output - Automatic delay finder. - 3rd input can be configured as a stereo AES digital interface. - very flexable routing, for ex you can do summed mono lows with stereo mids and highs, or 2-way stereo with a pair of delayed fullrange outputs, or stereo 3-way, or mono 6-way. Pretty much any config you need is available. - Wired remote control PC application. It's right out of the 90's and ideally requires a computer with a serial port.. but it works and is easy to navigate. Edited by Conanski - 09 December 2022 at 10:31pm |
SnailSpace
Thanks, Looks like I’ve got a lot of learning to do about crossovers! The only thing that puts me off it is that me mention of Serial Ports & PC’s! I don’t have a PC or a serial port! Could possibly use my wife’s work laptop but the connector is £100 alone on Thomann! Wow! Why is connectivity so outdated?
Conanski
The DCX can be fully configured from the front panel using the built-in display and controls, you don't need a computer to set it up it's just nicer to not have to squint at a small screen. People have also successfully used USB to serial converters to do this with newer computers.
Conanski
Yes and a good example would be the ART SLA1 or SLA2.
Edited by Conanski - 10 December 2022 at 2:57pm |
SnailSpace
Great!
SnailSpace
Just put it into the calculator and you’re right I looked in the wrong place at 2 speakers instead of 4, 4 said it would be a 1ohm output.
What speakers would you use in bridge mode? So what type of Series configuration would I be looking at setting up? Had a look at ART SLA1 & SLA2 thanks (and again was searching something else) out of the need to learn again and the fact they are around £300 - why would I choose this type of amp over something a touch bigger but cheaper if so what would the outcome be? Is it so I’m not over working the amp or the tweeters? Cheers
