  New Posts New Posts RSS Feed - What speakers use NEXO, where is the prove ?
Digbethdave View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Digbethdave Quote  Post ReplyReply Direct Link To This Post Posted: 11 April 2019 at 11:06pm
Originally posted by stamatis34 stamatis34 wrote:
For the Nexo Ps15, Ps15 bass,Alpha B1 the correct driver is the PHL B38-6030 & 6090!
The reason is that the voice coil is 4 inch and not 3 inch! nominal power for all are 1000-1200w and not 500w
Also if you calculate the 5021 94db & 500w you will end up really far from the spl nexo is presenting (134 for ps 15 and 140 for the hornload B1 +6db peak)
I own those cabins and i have performed reconing to them
Thanks
Late to the party, expecting beers.
StuMur View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StuMur Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2019 at 2:15am
Gold.
Mircea Bartic View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2019 at 8:25am
I can tell you for sure that Nexo PS10 R2 (the new model) have
 a OEM version of B&C 10NW76-8 woofer
Different suspension and added Copper shorting ring (and dual bonded spider)
regular 10NW76 has none of them.
it is not a regular off the shelf unit
I've reconed a few of those last year
Ex Nexus_3
Post Options Post Options   Thanks (0) Thanks(0)   Quote StuMur Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2019 at 9:03am
What about Nexo's PS8 boxes.. I have four, with the original HPA12ND 8" drivers in them, and I replaced two of them recently with B&C 8NDL51 neodymium woofers, as they were as close as I could find, and were cheap compared to branded Nexo ones. The two new ones sound much better than the original Nexo components, to my ears anyway - spectacular. I wonder if these new 8NDL51's are exactly the same speaker minus the Nexo sticker, and sound great just because they're brand new?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2019 at 10:50am
I'm pretty sure they are different. All nexo components I've come across had some differences from the off the shelf units.
Will they work? yes
Will they measure the same? No
Depending on the client it might not mater.
Ex Nexus_3
Post Options Post Options   Thanks (0) Thanks(0)   Quote StuMur Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2019 at 11:37pm
Will they work? yes
Depending on the client it might not matter.
Yes, agreed, there must be something different. They look identical, but have different serial numbers on them - God knows what might be different in spec. I bought two new ones for US$200 delivered, as opposed to much more than that if I'd bought the original items from Nexo. In my non-mission critical situation of running a double PS8 rig with subs for a Shania tribute show in arts centres, they work brilliantly - as well as the originals, and at full volume I'm flat out telling the difference, so happy days for 200 bucks! :-)
Edited by StuMur - 12 April 2019 at 11:39pm
SamV View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 15 April 2019 at 7:12am
Do note that if you do use different drivers, the active processing and protection may not operate the same.
csg View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote csg Quote  Post ReplyReply Direct Link To This Post Posted: 15 April 2019 at 8:27am
it will also wipe out the re-sale value that the brand holds
This page was generated in 0.535 seconds.
