  New Posts New Posts RSS Feed - what to do?
what to do?
novice View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote novice Quote  Post ReplyReply Direct Link To This Post Topic: what to do?
    Posted: 08 May 2006 at 4:52pm
okay, what to put above the scoops?
option 1: 12" horn mids, comp horns and bullets.
option 2: 15" horn low mids, 10" high mids, comp horns and bullets.
option 3: hd15s, 10", comp horns, bullets.
option4: ????
wanted to go for option 1, but finding it difficult to find 12" horn box to go down to 130Hz.
any thoughts soundmen?
mans1000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mans1000 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2006 at 5:00pm
I got scoops and use your option 1(but without bullets,these will be added soon).perfect for the music I play,Reggae,R'n'B.have a listen to as many Rigs as you can and see what sounds best for the type of music you play.
"The earth provides enough to satisfy every mans needs...but not every mans greed."
Tom Umney View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Umney Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2006 at 5:19pm
The Eminence plan 12 inch straight horns will easily go down to 120hz. Dom has a pair loaded of them with Eminence Delta 12 and wants £150 for them.
mykey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2006 at 1:10am
if you went option 3
you could do per stack
2 x scoops
1 x 15 hd
2 x 10'' horn
1 x 1'' horn - optional bullets
