  New Posts New Posts RSS Feed - what wattage on RCF loaded HOG
Natty K View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Natty K Quote  Post ReplyReply Direct Link To This Post Topic: what wattage on RCF loaded HOG
    Posted: 07 July 2009 at 2:49pm
hi what do people think i should run 2 hogs at running in a 4 ohm pair and can you work this out by getting the amps just clipping and reducing it proportionally on the level on the amp? (what is the best way to work out what you are putting into your speakers?). what should i run a usb at and in what config (ohms)? cheers
