what works with an X1 |
robotnation
Registered User Member Banned! Joined: 17 January 2006 Location: United States Status: Offline Points: 254 |
Posted: 05 March 2006 at 7:33pm |
i am slowly building an X1 for use in a dj setup, and i am looking ahead into plans for what midbass cabinets will work well when used with this subwoofer. The consensus seems to be "hd15!" but i really dont want a horn, and i REAlly dont liek the way the hd15 looks. I designed a cabinet that pulls an spl of 103db/w/m flat from 70 hz to 440 hz. though id need a ratio of 3 of my design to 1 X1, id still be getting way better frequency response for midbass. Going that high has a ripple effect. midtops crossed over at 440 hz dont have troubles with bass messing up the midrange drivers, so in theory i could use 6 inch drivers and some horns to build tiny midtops, all around for a really small but really loud system. does anyone know of a reflex design i could construct to pair with the x1 and get the same overall system spl response using fewer or smaller cabinets? perhaps i need some enlightenment on the difference between horn and reflex enclosures.
Andrew
Registered User Joined: 10 March 2004 Location: United Kingdom Status: Offline Points: 669 |
Stick some charcoal foam over the front of the HD15, it looks quite different and far less threatening this way.
LunchieTey
Young Croc Joined: 06 February 2005 Location: Australia Status: Offline Points: 934 |
Or a compact ported dual 15(v shaped front behind grill to reduce size) with a highish tuning frequency for powerhandling and sensitivity-easily capable of x1 output. Or like above, put a grille on a hd15! A 6" mid will struggle to keep up, maybe dual 8" with the horn mounted in between? Although this will still really only have the same output as a good 12/15? Why not just build a dual 12/15 cab and horn? If you want to keep it small it'll be better that a bunch of different cabs and amps to run them! |
Speaker addict
Tom Umney
Registered User Joined: 26 February 2004 Location: United Kingdom Status: Offline Points: 4954 |
http://www.fane-acoustics.com/public_html/media/pdf_media/Ca binets18inch200L.pdf It's possible that Fane 18 inch reflex design might be as good as the X1. as it goes down to 35hz.
robotnation
ahh yes... the dual 15" with v-shaped front is exactly the cabinet i envisioned. i have a question about this design though, because this is something i have no clue how to calculate--- my current design has a V shaped front, but the two ports are going to be situated at the back of the V toward the rear of the box. im assuming my V will have a slight horn effect, which brings me to my question... will putting ports at the back of the two horn regions effect phase and and stuff liek that? I suppose a better visual is that it is an M when viewed with the top of the box removed, with the bottom of teh M facing out and the top being the inside of the cabinet. if i put two ports in the rear crevices, will that be better than one port in the very middle up front? if this makes no sense then i will make a drawing and scan it tonight, but if someone has advice then id love to hear it, im totaly stumped. now im thinking... has anyone ever tried porting a speaker like the 1850 horn on the inside at the beggining of the horn? what exactly would that do? |
Jimbo
Registered User Joined: 07 March 2005 Location: United States Status: Offline Points: 420 |
Search this forum. The topic of porting into the horn has come up a few times. Jim |
