what would you do different? |
yesfam!
New Member Joined: 04 August 2010 Status: Offline Points: 3 |
Posted: 12 August 2010 at 9:11am |
Hi guys I am looking for some advice on the compatibility of some of the items i am looking at running, anything you would do differently? This is what I had in mind 2 x 12v sealed 50ah batteries run in series 1 x sure 4*100w @4 ohm amp 2 channels, each running 1 x 10" eminence ragin cujun 8ohm 75w rms 100db for my low end 1 channel running 1 x fane studio 5m 8ohm 100db 50wrms 1 channel running 1 x high-fi silk dome tweeter 3cm 8ohm 95db 40wrms 1.5khz-22khz 1x 3 way crossover and would really like to run a mini mixer in the setup, now if anyone has suggestions on a small, low power basic mixer that will happily run with this kind of setup I would be very grateful. Any potential problems you guys can see please feel free to pick my ideas apart and suggest alternatives. Thanks for your time guys.
Saturnus
Old Croc Joined: 13 July 2010 Location: Copenhagen Status: Offline Points: 2025 |
The tweeters sensitivity is much too low. You need something that can at least match the midrange. I have good experience with this one http://www.paudiothailand.com/pdf/products/PHT-407N.pdf It's reasonably priced, compact and light weight, and has good overall performance. |
yesfam!
Thanks for the help, I found the PHT-407N quite hard to find available on the net, I have now put a much more sensitive tweeter on my wish list now. still keeping my eyes open for some sort of basic mixer that is fairly energy efficient, I am only looking for a means to adjust bass and treble and a master volume control. Any suggestions? |
Saturnus
Btw, although the Sure does say 4x100W output into 4 Ohms, that's pretty optimistic too say the least. At 24V the éven theoretical maximum output power into 4 Ohms is 59W if we assume 82% effeciency as dictated by the amplifiers chips.
Let's for sake of ease say it's actually 4x60W into 4 Ohms instead, which in turn will make it 4x30W into the 8 Ohms speakers you use.
MunkeyQ
Registered User Beware,Scammer. Joined: 23 May 2009 Location: near london Status: Offline Points: 449 |
That Eminence is a guitar speaker, which isn't the best for your use by a long shot. Guitar speakers are designed to distort and colour the sound, which isn't what you want - they also tend to have a short excursion underhung motor and high Q + Fs, which won't give you much clean bass at all.
Look at the Eminence Alpha 10, reasonably priced and much more suitable for you. Generally speaking, drivers designed for guitar amps don't play nice when you don't want distortion. |
