  New Posts New Posts RSS Feed - What's better?
What's better?
Cheekybox View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cheekybox Quote  Post ReplyReply Direct Link To This Post Posted: 24 August 2020 at 8:45pm
Originally posted by Sypa Sypa wrote:
+1 for the cubo kick .
A stack od es18 over a stack od subs tho can help a bunch with 50-60hz impact if aligned correctly.
Would you overlap the points?
Cheers
bass*en*mass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 24 August 2020 at 8:56pm
yup.. but if your "subs"already peak at 45ish hz (scoops) you surely wont want another boost at 50ish hz, do you? unless its an spl drag race gig/clash but actual listening to music and its notes ;)
OP, if you need/looking for dedicated kicks, its either the cubo kick or front loaded horns in my books tbh., Marc Os flh plans on hornplans.fr do work well too, just make sure you use 4 per side ideally and get them close to your tops.. :)
