what's the correct delay settings for es18's/hogs |
Post Reply | Page 123> |
mashgwan
Young Croc Joined: 20 May 2004 Status: Offline Points: 613 |
Posted: 21 December 2012 at 10:06am |
hello
we are currently having 4 hogs made loaded with 1851's
we have 8 es18's to go above them loaded with challenger C650
there are for floodlight s which go above them
what are peoples sugested delay settings between the es18's and the hogs?
we are just going to play around with the crossover points but it would also be interesting to hear what other people are using for ther cross over point?
lukelucas93
Young Croc Joined: 05 July 2011 Location: Newcastle Status: Offline Points: 695 |
Also interested in this maybe Electrikal can shed some light on this
Luke |
Noodles, Cabs and Booze - Student life
fat_brstd
Old Croc Joined: 23 August 2008 Location: Melbourne, OZ Status: Offline Points: 2125 |
High pass at 32 or 35hz with a 48db butterworth up to about 75hz, to be honest with all those es-18s Id be thinking of crossing even lower than that say 60-65 and just use the hogs to add a bit of sub. How high are you running the es18's webby? 180 to meet the floods or lower than that? I always thought floodlights dont really go below 180
Melbournes Rootical Warrior Roots - Dub - Steppers facebook page |
mashgwan
adrian- i think the es 18s currently run up to 200
SouthwestCNC
Unearthing an old post here. But anyone have an awser to this question of delay.
toastyghost
Yes.
It depends. |
Sypa
Young Croc Joined: 21 February 2013 Location: Croatia Status: Offline Points: 920 |
1.75 meters on the dcx for me.
SouthwestCNC
1.75m between es18’s n hogs? Then going to be a couple of meters or more between tops and hogs? Edited by SouthwestCNC - 22 October 2017 at 5:52pm |
SouthwestCNC
In what respect? Time alignement between the two stacked flush should be a constant shouldnt it? |
levyte357-
Would estimate ES18 Horn length is approx .9M, and HOG Scoop is approx 2.2M, meaning delay should be approx 1.3M !?
And somehow, do not think ES18s will both play low and nicely upto 200hz, especially with heavy cone driver. |
PinHole
Registered User Joined: 14 September 2013 Location: behind you Status: Offline Points: 93 |
You have estimated wrong.
Signature is important. So I always write something in this dedicated field.
mini-mad
Pinhole, if he has estimated incorrectly would you be as so kind as to Give the correct answer.
