when a sealed box is better than vented? |
Post Reply | Page <1234> |
Author | ||||
bob4
from a historical perspective, amp power was comparably restricted and expensive for a long time, hence the need for horn and reflex loading to achieve satisfactory output levels (cinema, PA). A few years ago there was a big debate about alleged benefits and effectiveness of large sealed enclosure arrays in the german DIY/PA community that never drew to a conclusion - a little bit like the endless Scoop Wars here on SP..... Although, the germans tended to get a little bit more technical about it..... Edited by bob4 - 30 November 2014 at 9:34pm |
app
Old Croc Joined: 26 December 2013 Location: Finland Status: Offline Points: 2435 |
At the end of the day I think sound quality is more important than how loud it is! Altough I must admit that when I saw Aba Shanti and Jah Tubbys I loved the heaviness of their sound,on the flipside I was basically half deaf for many days which wasnt nice!
I think that people might get too caught up in making complicated designs when it might be smarter to keep it simple! I think the simplicity is an overlooked aspect of everything music related,like music production for example. A microphone hanging from the ceiling used to be enough,theres some quality recordings made really simple without using 254 channel mixers Of course evolution is important and you cant stop the progression but maybe its easy to over do things nowadays when theres too many possibilities and new things one can do. |
"what!?"
bitSmasher
Old Croc Joined: 23 June 2012 Location: Melbourne Status: Offline Points: 2295 |
Coincidental thread, I'm pondering this myself
Have been given 4x 15" salvaged from mid/top cabs, and want to do something with them Considering putting each in a ~70litre sealed box to run from 80/90 up, on top of reflex subs My assumption is with smoother phase the sealed boxes should be easier to integrate in a system than BR - is this correct? |
GEB
Old Croc Joined: 13 November 2009 Location: East Midlands Status: Offline Points: 1993 |
Yeah I'd say go for it dude. I've gotta wait whilst spring as I do most of my woodwork outside! Certainly gonna try some experimentation anyway. They say its quite hard to balls up a sealed bass cab as the design is so forgiving, which is always a bonus!
Thanks(1)
In the home where one can use boundaries (corners, walls and so forth) to add more SPL.
Most guys that use a kick bin are using midrange cabinets unable to reach 100 Hz. The vented/sealed route goes more to wards the TS Parameters of the loudspeaker, the cabinet size and, what is the desired frequencies the user is looking to agitate.
Ports can play factor all the way up to the mid range region. It really depends on the user requirements.
Read the above. Best Regards, |
GEB
Did you get any further on your 2x 12" box plans app?
Hopefully going to pick up the wood for mine in the next couple of weeks for my large single 12" box. |
app
I decided to go for 2 boxes instead. 35x35x35 inside diameter without the bracing and driver. Have not yet to test em properly. Whats a large single 12" box? |
"what!?"
GEB
Sorry should of been clearer. A large sealed enclosure, 12" driver, running 80/90hz - 180/200hz, depending on what sounds best.
app
No worries man. The test ive done in my living room suggests that the boxes will work well! Hard to say for sure since I dont have the guts to turn the system up in my one room apartment
I also need to test different crossover points...Hopefully next week! Ill try to take some video evidence... Good to hear that someones building something |
"what!?"
GEB
Try and post some pics dude. Pictures spur us all on to build more I think!
Edited by GEB - 10 January 2015 at 4:44pm |
b grade
Young Croc Joined: 05 October 2012 Location: Portland OR USA Status: Offline Points: 1337 |
If SPL is not the main goal, I love Sealed box sound. The group delay and phasing are usually so much easier on the ears.
app
"what!?"
