Whens the next scoop shootout? |
Post Reply | Page 123 5> |
S&P
Registered User Joined: 01 March 2008 Status: Offline Points: 222 |
Posted: 06 January 2011 at 6:55pm |
Title is self expanatory - any plans on one this year with several new designs having appeared?
Sounds and Pressure Lo Fi Sound - Ska, Rocksteady, Reggae
http://www.facebook.com/events/412323448834558/432237103509859/?comment_id=432362186830684¬if_t=event_mall_reply#!/groups/75371249167/ |
tweeter box
Old Croc Joined: 21 October 2007 Location: United Kingdom Status: Offline Points: 6784 |
in the not to far future i was told
luton_soundman
Old Croc Joined: 03 August 2010 Location: Bedfordshire Status: Offline Points: 4539 |
Took the words right out of my mouth S&P, This was my next topic i was going to post! Keep us informed Tweet
mykey-
Old Croc Joined: 03 March 2010 Location: ID/UK Status: Offline Points: 6114 |
count me in
new 21'' Scoop called 'Seismic' smaller than most with an output of a giant, hence the name H-1154mm (45.4'') x W-636mm (25.4'') x D-794mm (31.25'') Edited by mykey- - 16 January 2011 at 4:01am |
hmaudio
Old Croc Joined: 03 April 2009 Location: Nottingham Status: Offline Points: 3844 |
If its in the midlands count me in!
This account is used by 2 people. |
YoungBlood
Registered User Joined: 10 November 2007 Location: London/Jamaica Status: Offline Points: 442 |
hope the way ppl test this time is proper soundman test not flat eq stupid business
each box and driver should push to the limits with people voting |
"chyll wynstan.."
studio45
That won't be a fair test though. If you're really trying to compare BOXES, then everything else must stay the same - driver, amp, and signal feeding amp. Otherwise you're comparing different [box+driver+amp+preamp+operator] combinations, and that's like comparing apples and oranges and mangoes. The comparison would be meaningless. Not everyone would be able to buy the box alone and expect to get out of it the performance they hear at the shoot-out. If it was me running this, I'd say one experienced soundman who's used a wide variety of scoop based systems should set an EQ curve that's agreed to drive most scoops adequately, and that's acheivable on a standard graphic EQ or average LMS, not solely on one custom preamp that not everyone can have. Then every cab should be driven thru this EQ with the same amp and driver. This way the true differences between the cabs themselves will become apparent. If there is better performance possible with a certain cab by using a certain preamp/amp/driver combo far removed from the standard setup used for the comparative tests, this should be demonstrated in a seperate test. Then people can decide whether it's worth changing their drive setup to suit the new cabs or whether a different new cab will work well with their standard setup. Science need not be your enemy
burningbush
Old Croc Joined: 25 May 2009 Location: Pictland Status: Offline Points: 5897 |
Tested until flames were spitting forth, lol.
RENSAAB
Registered User Joined: 21 July 2005 Status: Offline Points: 402 |
Nice! Which 21" driver Mykey?
Who's conducting this scoop shootout?
"The secret of the Scoop, what a wonderful piece of Science" - Tony ASS.
"when the amplifier and voice coil are in complete synchronicity there is magic" - A Well Respected Amp Guru |
TRE4U2NV
Old Croc Joined: 21 May 2005 Location: home Status: Offline Points: 2592 |
'Seismic' aint you used that name before mike ?
YoungBlood
how can it be same driver for every box when everybody know turbomax no good in small chamber and 1850 best in small chamber full scoop? idiot ting dat you find out which driver best for box and then which box go loudest and deepest without blow up all rootsman know is when good preamp and strong amp on box is when you really hear it play can see this shootout ah joke ting already Edited by YoungBlood - 15 January 2011 at 7:12pm |
"chyll wynstan.."
Nitz V1505
Old Croc Joined: 16 September 2009 Location: UXBRIDGE Status: Offline Points: 1719 |
Listen Blood ,Studio was saying the best way to test a cab,seen!!!!!! But what are the chances of everyone having the same driver,pretty slim. So the shootout should be the best driver/cab combo like it has been in the past. Bring the preamp but after setting the thing shouldnt be touched (especially by the man like Tweeter!!!!!) for each scoop test. And blood irie up the I self,blessed.
Edited by Nitz V1505 - 15 January 2011 at 8:50pm |
& THE TOPS LIKE LIGHTNING..... |
